Android + Camera Peripheral
Question
Can I use the camera peripheral with android? If so would android automatically detect the camera peripheral if it is connected to the P64 (idk how it would) or would I have to code it in to detect that it is there?
(01-20-2016, 05:31 PM)T_ech Wrote: Can I use the camera peripheral with android? If so would android automatically detect the camera peripheral if it is connected to the P64 (idk how it would) or would I have to code it in to detect that it is there?
If using the Pine64 5M pixel camera module, the Android OS will detected by itself.
Thanks, I was planning on using the 5M camera that I buy from P64 shop Smile
P.S. As a community we should just say P64, makes it sound like a fancy N64 XD
(01-21-2016, 03:31 PM)T_ech Wrote: Thanks, I was planning on using the 5M camera that I buy from P64 shop Smile
Will there also be android support for the thermal camera? I was thinking I may have the 5MP camera and the thermal camera that you put on facebook, and flip between them the same way you do with front and back cameras on other android devices.
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 393,007 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 30,101 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 17,048 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,058 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,149 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,681 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,379 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 262,000 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,588 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 106,459 02-10-2019, 07:44 PM
Last Post: mmmarcus
