Emacs on Manjaro Kde
I compiled emacs from git yesterday on manjaro, adding —with-x-toolkit=lucid to configure
and the toolbar works fine. I think, it is a problem with gtk
(08-08-2020, 10:46 AM)ennoausberlin Wrote: I compiled emacs from git yesterday on manjaro, adding —with-x-toolkit=lucid to configure
Ok, I didn't use that parameter. I am aware of other KDE distributions such as Kubuntu and Opensuse which have emacs working without any issues on plasma; if there is any gtk problems, they are aware.
I suspect Manjaro KDE is using some dated libraries but who knows. I am on Debian testing Gnome now. Installed emacs and other software that I have trouble in finding Manjaro repositories. Hopefully I will settle down there without a problem.
PS: If you are interested in hearing the outcome; I can compile emacs with the x-toolkit=lucid option on Manjaro KDE and see if it makes a difference.
  Manjaro Sway Theme Broken Eighty8 1 302 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,781 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 352 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,181 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,264 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 426 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 919 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,032 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,997 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 783 08-18-2023, 02:06 AM
Last Post: juliamenendez
