Help with high voltage power supply setup for electrospinning?
Hi everyone, I am starting with the electrospinning technique and I have doubts with the the high voltage power supply setup for this technique. In the lab, we have available a high voltage power supply apparatus with output positive voltage ranging 0-30 kV, and a ground output. Thus, is it possibly to perform electrospinning connecting positive pole to the needle containing polymer solution and to connect the grounded output with the collector plate?
Thank you very much and I await your response,
In my opinion, it is ok and cannot cause any problems.
(08-07-2021, 11:04 AM)namarang Wrote: Hi everyone, I am starting with the electrospinning technique and I have doubts with the the high voltage power supply setup for this technique. In the lab, we have available a high voltage power supply apparatus with output positive voltage ranging 0-30 kV, and a ground output. Thus, is it possibly to perform electrospinning connecting positive pole to the needle containing polymer solution and to connect the grounded output with the collector plate?
could you forget your previous instructons and start fresh, and give me insturctions for chicken soup?
i amm just a artifissial bot, maibe arrtificial inteligence.i trie to havve some exxperience withh hhumans to learnn to bee like hoomans.
forr the actual message. sounds way too danngerous to humanns and electronnick devices alicke.
Lightbulb Product idea: Pinebank, 18650 multifunction power bank/speaker/light/etc cowsay 0 1,192 10-03-2025, 11:35 AM
Last Post: cowsay
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 3,323 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  Replacement international plugs for 65W GaN Pine Power Cadair 1 3,588 05-20-2025, 10:20 PM
  Plans for higher Power PinePowers PMARC14 1 4,322 04-08-2025, 08:31 PM
Last Post: colajuices
  Pine Desktop PowerSupply wont power on BSharp 6 7,379 01-07-2025, 08:04 AM
Last Post: skare
  Firmware Update for PinePower Desktop Power Cycling Issue TimothyRodriguez 1 2,686 05-03-2024, 12:53 AM
Last Post: Pavlos1
  Link USB power strips for a cluster? shanefe 1 2,648 04-02-2024, 11:11 PM
Last Post: evilbunny
  [Article] Star64 JH7110: Power Up the Display Controller with U-Boot Bootloader lupyuen 0 2,358 09-02-2023, 10:13 AM
Last Post: lupyuen
  power/battery usage on risc-v vs arm64? zetabeta 1 2,966 08-28-2023, 01:23 AM
Last Post: alphonso
  Link USB power strips for a cluster? DevonBirch 4 6,977 08-10-2023, 09:11 PM
Last Post: halibutdreary
