rock64-debian-mrfixit-190531.img.xz : missing /usr/lib/dri/rockchip_dri.so
Hello !
I have a V3 Rock64. No PSU or HDMI issues : i have XU4, RPI-1, RPI-2, BPI-M5 without problems.
- rock64-debian-mrfixit-190531.img.xz >> SD Card  :  it lags very much, when moving windows with LXDE.
- rock64-debian-mrfixit-190531.img.xz >> mmc Card (Foresee 16 Go) : i can't start X, xorg doesn't find /usr/lib/dri/rockchip_dri.so. Can't find this file on my disk.
- Armbian >> black lines on screen when moving windows in XFCE.
- Armbian >> dashboard moving up an down quickly when i move some windows (ex : PCManFM, but not galculator (?))
- Slackware XFCE : works great, but no dependencies supported by this OS (?).
- Ubuntu : i don't want.
- FreeBSD .img for Rock64 doesn't boot.
What distros work on your V3 board, please ?
Undecided
(07-30-2021, 05:20 PM)popi Wrote: Hello !
Try use this https://github.com/armbian/build/blob/ma.../xfwm4.xml settings for WM. Copy over in your home directory config/xfce4/xfconf/xfce-perchannel-xml/xfwm4.xml and try again. Or build image from sources.
(07-31-2021, 04:23 AM)igorp Wrote: Try use this https://github.com/armbian/build/blob/ma.../xfwm4.xml settings for WM. Copy over in your home directory config/xfce4/xfconf/xfce-perchannel-xml/xfwm4.xml and try again. Or build image from sources.
Thank you Igorp for your help  Blush
No luck, the black lines are still here, even after having changed the xfwm4.xml file.
This makes windows moving without showing inside, but those black lines..are still here  Angry coming from GPU/or driver (?).
No hope for this board : i have tested DietPi : it shows me on boot "5v error from gpio" messages.
Only slackware XFCE works good... for the moment.
Oups ! The Slackware doesn't boot from mmc, than i bought specialy for it  Dodgy
Cool : i have "NO OS" working for my Rock64 V3. Happy.
Undecided
How have you confirmed that you have no physical HDMI issues. I assume you have quality HDMI cables and no shorting at the HDMI headers on the board. I bought 5 Rock64 v2 boards and have confirmed that 2 of them have faulty ethernet sockets and 1 has a faulty USB2 socket possibly down to poor soldering. If you have any warranty left on the board I'd return it now.
I am pretty sure Armbian works on Rock64, even there is no official support. But you have to build it from sources - there were some important fixed added lately.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,549 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,153 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 97,757 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,133 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,658 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,647 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,023 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,211 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  problem with debian emmc boot G4zCDzWb 10 30,967 11-01-2024, 04:32 PM
Last Post: bits
  Debian installation via sd card oaFJSADBKV 0 2,692 10-12-2024, 10:24 AM
Last Post: oaFJSADBKV
