Arch Linux ARM root filesystem
Thank you so much for this !
I've successfully migrated from Nadia's repos using your FAQ. I've only had to comment the
LABEL=BOOT_ALARM  /boot  vfat    defaults        0      0
line from /etc/fstab to boot properly.
(06-29-2021, 02:18 AM)SKiljan Wrote: If you want to donate money specifically for Arch Linux ARM on Pinebook Pro, see if there is something upstream for which it can help.
I made a donation to Arch Linux Arm: https://archlinuxarm.org/about/donate
Thanks again.
nice instruction with root luks
https://ryankozak.com/luks-encrypted-arc...pro-again/
(06-20-2021, 10:53 AM)SKiljan Wrote: ... I decided to take up the torch. This new repository contains a root filesystem for installation and installation instructions:
Many thanks - easy to follow instructions, swapped the dtb in extlinux for rockpro64 and it runs, as far as I have played, flawlessly on my RockPro64.
Even better - booting from the SDcard both the eMMC & NVMe are visible which is really promising - something I have never achieved before with any kernel higher than 4.4 (tried Armbian, Manjaro etc - on any of those the boot hangs if the eMMC is present).
Still a lot of playing/learning to do but so far really likely to be able to swap to arch on my RockPro64: so far no problems with USB, Eth0, HDMI, eMMC & NVMe. Nothing too scary in the logs - still need to see if I have any sound, and probably benchmark the eMMC & NVMe. Could generate the pacman keyring fine and even update to the 5.13.1 kernel.
Thank you again
Wink
(07-08-2021, 09:03 PM)josmo Wrote: nice instruction  with root luks
Thanks Smile
  • PinePhone BraveHeart, needs modem replaced, used for experimenting with new OS's.
  • PinePhone Manjaro Community v1.2b 2G/16Gb Daily Driver
  • Pinebook Pro Arch Linux, Daily Driver
Thanks for your work !
Sorry, but i might have a few stupid questions…
<edit>indeed they were ! I found plenty of good informations on your FAQ, in the arch style we like Wink I replace my old kernel with yours and everything works like a charm, so i updated with all your packages and it's fine. If i install a SSDNVMe drive one of these days i would also try tow-boot. I would try it before if there are good reasons you would give. Thanks for everything !<edit>
I run an ALARM distro on my pinebook-pro that i made more than a year ago from a manjaro system following the «arch way» : i think i created and mounted the desired partition and then pacman some packages from the alarm repo and the specific ones for the pbp from a repo that was called simulated-earth. Helas, this repo died very soon and i havent updated my kernel, neither u-boot for a year ! (I do have the bluetooth security bug…). I sometimes tried nadia's kernel but it breaks the usb-c hdmi output that works the whole time with this pretty old kernel. I'd like to try yours, and i was searching for the archive of the package but could not find it (just the PKGBUILD).
Do you host such a .tar file that i could pacman -U ? (i guess with a slight modification of the extlinux.conf file ?)
Or can you give the address of your repo that i could add to my pacman.conf ? (i could not find it too…)
<edit>ok, i have found it, i'm gonna try to install your kernel. Btw, what does the «post-install» package do, cause pacman wants to update mine from april 2020 with yours, but i fear that it could break something… ?<edit>
I always complain about the boot process of this ARM devices that i dont master at all and regret we cant chose different kernels at boot (so that i could try different ones…). Is this possible with tow-boot ? I have seen you maintain both a u-boot PKGBUILD and a tow-boot one. If i could install your packages, would i just have to dd the right files to the right places or would it be more complicated ?
Bref, i'd like to migrate to your solution but i fear to break everything that work pretty well so far…
<edit>Sorry, many informations where in your GIT FAQ…<edit>
(In the meantime, i could try your image on an SDcard…)
Thanks again for your work, and, I hope, for your answer Wink
alex
Smile
Thanks a lot for all your hard work!  Smile
I just got EndeavourOS ARM loaded up on my Pinebook (SD card for a first test), and so far everything works great.
I set it up with f2fs instead of ext4 and it worked without a hitch.  Performance is noticeably better than my Manjaro install (ext4). From the install instructions, I just replaced
mkfs.ext4 -L ROOT_ALARM /dev/mmcblk2p2
with
mkfs.f2fs -l ROOT_ALARM -O extra_attr,inode_checksum,sb_checksum /dev/mmcblk2p2
(the additional options are recommended on the arch wiki)
has your GPG key for the archlinuxarm-pbp repo changed ?
I've been getting GPGME errors for a couple of weeks.
pacman-key --populate reports that the gpg file is missing.
I was using Nadia's u-boot build before, but this TowBoot thing seems to werk pretty good, too!
(09-10-2021, 12:35 AM)flyingscorpio Wrote: Hi,
No issues here. Is it possible time is configured incorrectly on your system?
https://github.com/SvenKiljan/archlinuxa...nebook-pro
  Can’t login to Linux fnosai 0 2,044 07-27-2025, 12:30 AM
Last Post: fnosai
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 2,079 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 4,401 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Slackware Linux working on PBP vxzero 0 2,793 06-05-2024, 04:30 PM
Last Post: vxzero
  By the way, yay arch... KC9UDX 4 4,489 03-30-2024, 10:27 PM
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 5,427 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 2,264 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 237,336 05-03-2023, 06:10 AM
Last Post: dachalife
  Encrypted Root jaredoconnor 1 2,337 01-19-2023, 02:27 PM
Last Post: Cs137
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 2,944 11-28-2022, 05:03 PM
