Java on Manjaro ARM Pinebook Pro
Hello all!
I just got my PineBook Pro in the mail and have been getting used to Manjaro (I have been a regular user of Ubuntu/Debian before). I want to install Java so I can code and work in Java projects using the PBP, however the arm architecture has allegedly been causing me some issues. I installed YAY and did yay -S jdk and then chose jre11, but I get the following warning: the following packages are not compatible with your architechture: jre11. Should I try to build them anyway? Any help is welcome, I figured I would ask others who have succeeded in installing java, with its necessary jdk and jre, on your PBPs.
  • Should I be trying to install JRE11?
  • What jdk should I get?
  • Any other things that will be necessary to get java development up and running on my PBP?
Any help is welcome, thank you very much for your time.
Cheers from Portugal!
when yay asked you that question, did you tell it yes? a quick look at some other similar forums indicates you should be able to get this installed, but you'll need to build it
(05-25-2021, 10:37 AM)tophneal Wrote: when yay asked you that question, did you tell it yes? a quick look at some other similar forums indicates you should be able to get this installed, but you'll need to build it
Thank you for your reply.
I did not tell it yes, since I wanted to be sure and ask people with more experience beforehand. I will go ahead and say yes, no clue on how to go on to building it. I installed vscodium from the AUR through yay I believe and it took a while, lots of choices in between, I presume it should be something similar? Will report back with further info. Thank you again!
That is one thing to love about yay, it will build it for you (if it can.) it's very useful for all kinds of software (but not all) that may not have proper aarch64 support. it's always worth a shot whenever it asks! Hope it builds for you!
  default login & password, Pinebook Pro? kiloseven 1 1,925 12-11-2025, 12:11 AM
Last Post: kiloseven
  Running Linux on Pinebook Pro with External Monitor Twers1962 2 3,663 03-25-2025, 11:10 PM
Last Post: Dendrocalamus64
  Pinebook Pro vs Pinetab2 Lotech 5 6,810 12-10-2024, 09:10 PM
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 6,965 12-10-2024, 07:23 PM
  New User use PineBookPro default OS Manjaro clessard 0 3,170 07-02-2022, 09:01 AM
Last Post: clessard
  Invalid package error in Manjaro-ARM? Easy fix 98cwitr 0 3,359 05-23-2022, 08:49 AM
Last Post: 98cwitr
  Please Help: Bricked Pinebook Pro with Keyboard Update dumbguywhobrokehiscomputer 3 8,284 07-14-2021, 02:49 PM
  Setup My Pinebook 64 and Lost Password jersdayoff 5 13,093 05-01-2021, 10:29 PM
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 5,716 02-02-2021, 12:13 AM
Last Post: PineSupporter
  How to boot from SD card on pinebook pro linux123 3 10,514 12-02-2020, 10:29 AM
Last Post: linux123
