PinePhone Beta Edition will not boot from MicroSD card
Very interesting that it can be set up to ignore the card detection. I wonder if there is a specific reason that card detection is turned on, because if there isn't then I agree that having it off by default sounds like a much better idea.
I think it's just the default for U-Boot. It's used on a lot of other devices.
I asked DanctNIX on Discord if they could compile a modified U-Boot. A JumpDrive with the modified U-Boot would let you reflash your internal eMMC. https://discord.gg/AvtdRJ3
(05-08-2021, 10:35 AM)8bit Wrote: I think it's just the default for U-Boot. It's used on a lot of other devices.
That would be interesting to try and see if it works.
Since this PinePhone is still under warranty Pine64 has given me a RMA number so I can ship it to them and get a replacement. Should I wait a few days to try a modified U-Boot to see if this would be a workaround for the problem so that others know the solution, or should I just send it out?
Thanks again for helping me troubleshoot this issue so I could confirm that it is a hardware problem!
(05-09-2021, 07:05 PM)Timothy_Ecc Wrote: Since this PinePhone is still under warranty Pine64 has given me a RMA number so I can ship it to them and get a replacement. Should I wait a few days to try a modified U-Boot to see if this would be a workaround for the problem so that others know the solution, or should I just send it out?
I would send it in, I think I can make mine fail again. I took a look at it with the board out of the phone and can see how the switch pin is bent and wedged against the metal shell.
If you still have it, I managed to compile JumpDrive with CONFIG_MMC_BROKEN_CD https://github.com/8bitgc/Jumpdrive/tree/master/test
It boots fine but have not tried to break mine yet to see if it bypasses the broken switch.
(05-10-2021, 02:40 PM)8bit Wrote: If you still have it, I managed to compile JumpDrive with CONFIG_MMC_BROKEN_CD https://github.com/8bitgc/Jumpdrive/tree/master/test
I gave it a try. On both of my PinePhones I get the error below. I think this still proves that little switch is the problem though since it boots further on the damaged phone than it would before.
[font=monospace][color=#000000]DRAM: 4096 MiB [/color]
Trying to boot from MMC1
NOTICE:  BL31: v2.2():0.7-6-g3383f27
NOTICE:  BL31: Built : 09:44:36, May 10 2021
NOTICE:  BL31: Detected Allwinner A64/H64/R18 SoC (1689)
NOTICE:  BL31: Found U-Boot DTB at 0x4063a38, model: PinePhone
NOTICE:  PSCI: System suspend is unavailable
U-Boot 2020.04 (May 10 2021 - 10:25:36 -1000)
DRAM:  3 GiB
"Synchronous Abort" handler, esr 0x02000000
elr: 00000000fff73d64 lr : 00000000fff74064
x0 : 00000000ffff0000 x1 : 00000000ffff0000
x2 : 000000004a063a38 x3 : 000000004a063a38
x4 : 00000000fffb9200 x5 : 0000000000017404
x6 : 00000000ffffffd8 x7 : 00000000000178c0
x8 : 0000000000017888 x9 : 00000000b5f74000
x10: 000000004a045200 x11: 000000004a001850
x12: 0000000000000006 x13: 000000000001869f
x14: 000000004a063a38 x15: 0000000000000000
x16: 000000004a02b100 x17: 0000000000000000
x18: 00000000fbf53df0 x19: 00000000ffff0000
x20: 0000000000006000 x21: 0000000000000000
x22: 0000000000000000 x23: 0000000000000000
x24: 00000000fffc8000 x25: 00000000fffffff7
x26: 0000000000000000 x27: 0000000000000000
x28: 0000000000000000 x29: 00000000fbf4dce0
Code: 06aab249 d6683444 5558340c 466a3554 (76ca3535)
Resetting CPU ...
resetting ...
Thanks for testing. The CONFIG_MMC_BROKEN_CD seems to do what it's supposed to.
I was able to boot and flash a 2GB 1.2 (UBports) phone with this image. I think I need to pull the correct branch for 3GB to work.
Do you have to ship your phone back to Hong Kong, or do they have a US address for RMA?
(05-10-2021, 07:50 PM)8bit Wrote: Thanks for testing. The CONFIG_MMC_BROKEN_CD seems to do what it's supposed to.
I wondered if it was for the 2GB version and that was why, both of the ones I tried were 3GB.
Thankfully there is a US address for RMA. In my case, they actually only want the Mainboard so I got to disassemble it for the first time. Those ribbon cables sure are tiny!
Make sure you keep the rubber boot on the proximity sensor. Usually gets stuck to display, but it can stick to the mainboard. They don't have spares for those.
  Pinephone + Keyboard for sale, little use ruemoo 16 11,919 07-07-2026, 04:47 PM
Last Post: PinePhoneProUser
  Pinephone - broken power button rorus 14 24,018 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 1,636 01-20-2026, 01:43 PM
Last Post: Anna
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 20,175 12-12-2025, 03:27 AM
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 7,948 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 3,153 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 2,404 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 5,872 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 4,211 06-21-2025, 05:19 PM
Last Post: mikeb
  Does anyone know which testpoint is for Fel boot? Jodiwe 1 2,780 03-27-2025, 11:25 AM
Last Post: Jodiwe
