Does anyone know which testpoint is for Fel boot?
Hi all,
I'd like to be able to boot my Pinephone using FEL boot without using the SD card. I've had success doing this for a Banana Pi, and a Pine64, so I would like to maybe make this an option for the pinephone as well.
Has anyone figured out which testpoint is the FEL boot pin on the 1.2 board? Did we ever get a proper layout for the 1.2 board?
Thanks!
I figured it out!
I measured each testpoint when the phone was plugged in to find the ones that are ~3V. On startup I then shorted them individually to ground while plugging it into my computer. It's the second testpoint of the 6 next to the radio on the top side of the mainboard.
Here are pictures of the mod I did to make it available from just in the battery cover:
[Image: hcENtBY.jpeg]
[Image: kEn4hSm.jpeg]
I'm trying to build u-boot at the moment. Wish me luck :-).
  PinePhone Beta dead - no boot-related output on serial interface horalocal 1 3,926 02-15-2023, 11:21 AM
Last Post: fxc
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 46,203 01-29-2023, 12:20 PM
Last Post: skandigraun
  Pinephone won't boot from SD card arkadione 3 8,252 05-25-2022, 03:26 PM
Last Post: sfb
  Pinephone wont boot after updating Phtevenz 1 3,767 10-26-2021, 11:31 PM
Last Post: bcnaz
  Red LED when trying to boot from SD card. Need advice. サーバント 5 10,022 10-20-2021, 09:40 AM
  Won't boot until connected to power after sudden power loss brb78 1 3,914 08-30-2021, 12:41 AM
Last Post: bcnaz
  Mainboard replacement does not boot/charge boarf 2 5,469 05-02-2021, 10:47 AM
Last Post: boarf
  PinePhone won't boot, U-Boot seems to be broken Marcade 8 14,856 04-20-2021, 05:28 PM
Last Post: dsimic
  UBPorts Edition - no boot screen danny_h69 3 8,268 07-21-2020, 05:39 PM
Last Post: danny_h69
  Boot problems pvdv 5 8,856 07-21-2020, 02:54 AM
Last Post: pvdv
