UBPorts Edition - no boot screen
Hi.
I'm sorry if this has been answered, but I couldn't find any threads relating to this.
I have the UB Ports edition with the pre-installed UT os.  It boots fine and starts as it should.
But, when I hold the volume up and power button together, it launches into an "Installing update" screen and just hangs.  I have left it like that for 24hrs...
I have tried to boot it with Mobian flashed onto an sd card, but Mobian will not boot.  Although I have seen that issue in other threads.
It also won't update from the repo.  I just get an error message saying the repo is read only?
Any help would be appreciated.
Dan
I have also seen this "installing update" screen while touching the buttons during boot.
In my case I can start Mobian from a sd card without problems. First I see a boot screen then the screen becomes black for a short time. Then I see Mobian.
Did you resize the partition like described at the end of this page? https://wiki.mobian-project.org/doku.php?id=install
Bye,
Paul
(07-20-2020, 05:35 AM)danny_h69 Wrote: Hi.
When in this state, try and connect your phone to a PC via cable. You are now in file transfer mode.
This is not as good as a connection from within UB Touch, but it works and you can even edit and flash partitions!
(07-21-2020, 03:07 AM)pvdv Wrote: I have also seen this "installing update" screen while touching the buttons during boot.
Bye,
Paul
Hi Paul.  Thank you for responding and the link to the Mobian wiki.  I resized the partition for the UT os, but at this stage I can't boot into Mobian via SD card to resize that partition.
I'll give Zweitaktmotor's suggestion for the "Installing update" issue and then have another go at a Mobian install from the wiki.
Thanks again.
Thanks Zweitaktmotor I'll give that a try.
  Screen dying already? marcih 156 310,580 06-12-2025, 06:18 AM
Last Post: mikeb
  Does anyone know which testpoint is for Fel boot? Jodiwe 1 3,629 03-27-2025, 11:25 AM
Last Post: Jodiwe
  Screen Replacement Instructions erikkugel 5 12,441 02-24-2025, 06:55 AM
Last Post: anonymous
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 2,121 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 6,905 10-12-2023, 01:03 PM
Last Post: robthebold
  No calls on Pine Phone Beta convergence edition polypode 1 3,839 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  PinePhone Beta dead - no boot-related output on serial interface horalocal 1 4,022 02-15-2023, 11:21 AM
Last Post: fxc
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 47,022 01-29-2023, 12:20 PM
Last Post: skandigraun
  BETA edition rcu errors 8bit 29 44,687 11-02-2022, 01:40 PM
Last Post: some_pinephone_user
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 8,818 07-25-2022, 07:35 AM
Last Post: bedtime
