control RP64 power on
  I am trying to find a way to control the power on/power off on my RP64 cluster nodes in order to switch off some unused units during the night and of course switch on some of them when the cluster reaches a load threshold. So far I am thinking of three ways (suggested by some pine64 irc users):
- use the GPIO communication to control the 4 pin header
- use a relay that controls the power supply
- use a PoE switch with a splitter
Has someone solved this topic or have any suggestions ?
LMM
  RockPro64 automatically run after power recovery - my solution g2t 1 180 05-28-2026, 05:29 PM
  Rock Pro 64 Won't power on matthewmkr 9 6,335 04-29-2025, 12:57 PM
Last Post: matthewmkr
  power button not working Vista8720 0 2,707 05-07-2024, 11:26 PM
Last Post: Vista8720
  enble boot after power loss/restore dkebler 18 25,737 12-04-2023, 12:14 PM
Last Post: ok38
Photo Max Resolution Supported by RP64? hoarfrosty 3 5,163 10-24-2023, 09:58 AM
  PCIE interface power on too late Slark Xiao 0 2,558 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  Automatic power on after power outage gechu 1 5,300 11-17-2022, 06:13 PM
Last Post: acj_
  After Power Loss feature working bdherouville 2 5,206 08-22-2022, 03:52 AM
Last Post: bdherouville
  PWM fan control low power Connar 0 2,554 12-12-2021, 05:58 AM
Last Post: Connar
  Flashed SPI, able to ping RP64 but not boot from sdcard/usb korefuji 2 5,099 08-26-2021, 11:41 AM
Last Post: LMM
