No Sound on Default Manjaro KDE
So, I have no sound on Manjaro KDE through either the speakers or the regular headphone jack.  I think this happened after an update, and I don't think I've changed anything, but I don't use sound terribly frequently, so I may have done something.  This is what I've found out so far: I asked over in the Manjaro forum, but it appears they're stumped.  Anybody here have any troubleshooting ideas?
What I usually do when my audio settings go wrong is I copy the default alsa config from the post-install package...
https://gitlab.manjaro.org/manjaro-arm/p...ound.state
the file lives in /var/lib/alsa and contains the current config, so if you overwrite it there, you get the defaults again
(03-31-2021, 09:00 AM)xalius Wrote: What I usually do when my audio settings go wrong is I copy the default alsa config from the post-install package...
Thanks for the troubleshooting idea, but sadly, I did what you suggested and it still didn't work.  Are you able to get sound on the latest Manjaro KDE?
My old install and a new image booted from sdcard work fine so far
(04-01-2021, 05:12 AM)xalius Wrote: My old install and a new image booted from sdcard work fine so far
Hmmm....may be a time for a reinstall then when I get my hands on another SD card.
  Manjaro versions bad and good gilwood 0 2,763 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,151 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 5,052 12-13-2023, 08:17 PM
Last Post: trillobite
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 2,983 07-13-2023, 01:50 PM
Last Post: PaulQ
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 488,643 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 5,628 05-08-2023, 11:17 AM
  PBP blank screen after updating Manjaro Franko 6 7,916 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 2,215 04-01-2023, 03:21 AM
Last Post: hacknix
  Partial boot after installing Manjaro on emmc regivanx 11 11,806 02-06-2023, 09:11 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 14,085 01-22-2023, 10:05 PM
Last Post: rfm83
