PinePhone Pin/password question
It seems to me that when I try to change my password via the terminal, it also changes the PIN needed to unlock the phone, am I wrong? If so, how do you deal with a "complex" password?
Example:
PIN was, 12345 when I changed my password via passwd to "Ihatewindows" in the shell, the PIN 12345 no longer unlocks the phone.
Is there a better way to do this, or is it a limitation of m@bain?
Thanks,
Denis
(03-27-2021, 08:04 AM)dgdimick Wrote: It seems to me that when I try to change my password via the terminal, it also changes the PIN needed to unlock the phone, am I wrong? If so, how do you deal with a "complex" password?
Have you thought about using a SSH key?
(03-27-2021, 08:04 AM)dgdimick Wrote: ... is it a limitation of m@bain?
It is a limitation of phosh. The user password has to be digits only as the irksome security screen (that I wish I could get rid of) only provides a keyboard with digits!
I've found that if you hang a KB off of the phone it will allow you to connect to it before the PIN screen, however, I have not tried to us a complex password as a PIN. I reinstalled Phosh, and the latest didn't allow me to encrypt the file system.
I may have to try another disto, however, I've loaded so many applications it may not happen for a bit.
  PinePhone Game Thread PixelPaintbrush 31 80,003 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 22,137 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 6,908 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 7,102 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 952 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,186 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,732 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,338 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 6,754 10-21-2025, 12:12 PM
Last Post: Richy_T
  Does PinePhone support long-term battery health optimization? roseblack 5 3,134 10-06-2025, 09:05 PM
