PinePhone Pin/password question
It seems to me that when I try to change my password via the terminal, it also changes the PIN needed to unlock the phone, am I wrong? If so, how do you deal with a "complex" password?
Example:
PIN was, 12345 when I changed my password via passwd to "Ihatewindows" in the shell, the PIN 12345 no longer unlocks the phone.
Is there a better way to do this, or is it a limitation of m@bain?
Thanks,
Denis
(03-27-2021, 08:04 AM)dgdimick Wrote: It seems to me that when I try to change my password via the terminal, it also changes the PIN needed to unlock the phone, am I wrong? If so, how do you deal with a "complex" password?
Have you thought about using a SSH key?
(03-27-2021, 08:04 AM)dgdimick Wrote: ... is it a limitation of m@bain?
It is a limitation of phosh. The user password has to be digits only as the irksome security screen (that I wish I could get rid of) only provides a keyboard with digits!
I've found that if you hang a KB off of the phone it will allow you to connect to it before the PIN screen, however, I have not tried to us a complex password as a PIN. I reinstalled Phosh, and the latest didn't allow me to encrypt the file system.
I may have to try another disto, however, I've loaded so many applications it may not happen for a bit.
  Pinephone visibly losing power while plugged in Hiraghm 10 9,861 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 2,038 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 88,550 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 26,824 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 9,022 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,798 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,423 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,084 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,461 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,889 10-21-2025, 12:12 PM
Last Post: Richy_T
