After update in Ubuntu bionic mate system crashed
I have Pinebook Pro and  I just succesfully flashed bionic-mate-pinebookpro-0.9.14-1159-armhf on emmc. But when I update system with the Software Updater and restart the PC, after restart it will stop on booting screen and this screen flashes and nothing happens, the system will not load. The system will not load even if I restart it a second time.
Before, I thought it was this error message on picture 1.png, but regardless of whether I chose keep or replace every time it turned out the same.
I made the flash with the same system on flashed sd card, I flashed with balena etcher program and I flashed the system successfully. The same problem occurred when I installed the updates of this system on the sd card, until i did it all worked fine.
Thank you in advance for any answers.
PS: Sorry for my english.
Update!: I tried to flashed older version Ubuntu mate - bionic-mate-pinebookpro-0.8.3-1141-armhf.img.xz stable. But when I do it, the system cannot start and from SD card (0.8.3 version too) either.
When I turn on charged notebook, there are no flashing lights and I don't see anything, but in while I hear ubuntu login screen sound. And nothing else happened and that's all. I feel warm procesor too.
I don't know what to do.
Thanks for any help.
Exactly same Problem for me.
Have you found a workaround?
(03-26-2021, 08:06 AM)Zeronius Wrote: Exactly same Problem for me.
No, I just made it worse. If you want to use it on daily base, you can boot from SD card and don't update. I done this before then notebook stopped responding completely.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,700 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 4,185 03-01-2024, 06:46 PM
Last Post: Puckla
  Fedora 36 -> 37 upgrade kills system tydeman 0 2,441 10-28-2023, 09:53 AM
Last Post: tydeman
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 4,941 08-21-2023, 09:10 PM
Last Post: vanessadonald
  Manjaro update: nerd-font-terminus dependency issue Vinay 3 4,734 05-10-2023, 04:51 AM
Last Post: Vinay
  Manjaro update broke hardware video acceleration with mpv myself600 2 5,059 01-25-2023, 09:12 AM
Last Post: myself600
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 4,952 12-09-2022, 12:43 PM
Last Post: as365n4
  WiFi stopped on Pinebook Pro after update tkudog 3 8,008 11-24-2022, 04:32 PM
Last Post: tkudog
  Manjaro update: wxgtk dependency issue Vinay 5 7,837 09-09-2022, 12:03 PM
Last Post: Vinay
  Error trying to update Manjaro software boosterh 5 9,328 08-31-2022, 10:28 PM
Last Post: shulamy
