Best Place To Learn PostmarketOS
I flashed PostmarketOS and found out it was bare bones, so I tried to add apps and such but it isn't easy for someone that has no clue about how
to navigate in apk. I did get a couple installed....
Where can I go to get a tutorial or something? The phone seems to be solid, phone quality sounds a whole lot better than Mobian and it works....
Messaging works also, I need to get my contacts imported, a couple of apps for music and podcasts is all. I managed to get Gpodder and lollypop installed but
it didn't work....
Any help would be appreciated.
(03-06-2021, 02:28 PM)mw4jet Wrote: I flashed PostmarketOS and found out it was bare bones, so I tried to add apps and such but it isn't easy for someone that has no clue about how
it didn't work....
https://wiki.postmarketos.org/wiki/Main_Page
You are going to find PostMarket OS is much more beta then a finished product like Mobian. Were you running the latest updates in Mobian?
it didn't work....
I just flashed todays release of Mobian, going try it out. Thanks.
it didn't work....
Still run the updates from the terminal. There were more just rolled out.
sudo apt update && sudo apt dist-upgrade
sudo apt autoremove
Run the code at least every other day. With the release of the Mobian CE edition development is rapid. Updates are rolling out rapidly.
Read the Wiki to tweak. https://wiki.mobian-project.org/doku.php?id=tweaks
Follow the blog upgrade instructions. https://blog.mobian-project.org/posts/20...pam_issue/
Follow the blog. https://mobian-project.org/
Add flatpak and install Chromium. It's much faster and supports Web Apps.
https://forum.pine64.org/showthread.php?tid=13235
Follow the live Mobian chat. https://matrix.to/#/#mobian:matrix.org
Mobian is the most stable and evolved OS for the PinePhone at the moment. Arch is right behind But lacks a few things and isn't as stable in convergence docked, followed by Manjaro Phosh. Plasma anything is a mess.
If I helped you rate me a +1 please? It makes up for the lousy pay they pay me here in the forum. Big Grin
thanks for giving me some insight into overwhelming amount of o/s's available for the pinephone! it is hard for me to understand who exactly is doing what. i started out with plasma-mobile pre installed and after a couple of weeks was running into way too many issues. i recently installed phosh to a sd card and like it much better. i'm still working on sound quality issues when using the phone though. based on what you've said, i may try mobian soon. i only need basic functionality but it has to be reliable especially for the modem, chat, and the phone. you get you +1.
it didn't work....
Check out the Alpine site: pkgs.alpinelinux.org -- Got me started.  also nixCraft cyberciti.biz .
For a brief guide to pmOS's differences:
http://postmarketos.org/cheatsheet
FWIW I had great results with Arch and Mobian.
Arch releases here: https://github.com/dreemurrs-embedded/Pi...h/releases
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 3 7,665 11-18-2024, 02:23 AM
Last Post: linmob
  How to include desktop file and icon in a postmarketos package patrickMcDonald 0 3,332 07-27-2023, 12:34 PM
Last Post: patrickMcDonald
  installed postmarketos v23.06 no audio samlo 1 4,455 07-14-2023, 12:53 AM
Last Post: samlo
  Scanning with PostmarketOS AndyM 1 3,962 07-01-2023, 08:16 AM
Last Post: AndyM
  VPN for PostmarketOS publiclewdness 1 4,991 03-11-2023, 04:35 PM
  Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue X0X0X0X0X0 1 4,935 02-11-2023, 08:19 AM
Last Post: acid andy
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 4,245 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 6,393 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  Pinephone Keyboard Utilities on postmarketOS elof 2 7,196 06-20-2022, 01:33 PM
Last Post: elof
  [PostmarketOS with Plasma Mobile] Angelfish adblock + wpa supplicant time out Egolep 0 3,529 03-23-2021, 10:25 AM
Last Post: Egolep
