OpenMandriva to release ARM builds for PineBook Pro and Pi
Err, perhaps you know, or perhaps not,,, every compressed file, zip, gz, xz whatever
is pretty much --self-checking--,, that is, if any bits flip, any at all, it will error out
Or, xz -t somefile.xz
You may know, the rk3399 will use whatever uboot it finds FIRST, likely whatever is on emmc
What is on your emmc?
thanks
(03-02-2021, 01:29 PM)wdt Wrote: Err, perhaps you know, or perhaps not,,, every compressed file, zip, gz, xz whatever
I can only say that the sha of the two files I downloaded were not the same. Hell, even the file size was not the same. They both copied to SD fine. One didn't boot, the other did. Perhaps an issue with the tool or a wrong link. Might have been an old cache in an sf.net mirror. I don't remember at the moment. It was a a week or two ago.
Quote:You may know, the rk3399 will use whatever uboot it finds FIRST, likely whatever is on emmc
thanks
Initially the Debian shipped with the device. Then flashed over with the Manjaro image.
I might be getting confused with another sbc, but I thought first selection was based on a jumper. (Might be thinking about my ci20 though.)
  Boot Order in Pinebook Pro food 14 19,331 Yesterday, 08:39 PM
Last Post: noahclark
  Window Maker Live for Pinebook Pro vajak 9 6,591 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,275 08-09-2025, 06:53 AM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,707 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,795 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,538 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 17,849 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,420 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,651 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 164,906 12-08-2023, 11:25 PM
