Working modem?
Well, after many months of trying to get this thing to work, I think I'm ready to give up on it.
(02-21-2021, 04:31 AM)Barugon Wrote: Well, after many months of trying to get this thing to work, I think I'm ready to give up on it.
Hi, I can try to help Cool  .
1. Who is your service provider?
2. What is your geographic region?
3. Exactly which Phosh OS are you using now? (Should be Mobian, IMO)
O.T.M. (Other Than Mobian) distros were very difficult to get 4G up and running.
Cheers!
In my experience, only the Mobian image can handle incoming calls from suspend currently. (eg25-manager)
From time to time cellular connection will get lost and you need to reboot.
The problem already occurred one year ago, several developers work on a solution.
https://gitlab.freedesktop.org/mobile-br...issues/194
(02-21-2021, 08:25 AM)MtnSk8 Wrote: Hi, I can try to help Cool  .
Cheers!
1. Straightalk. the APN is simply RESELLER.
2. Southern California.
3. I installed Arch a few days ago but I had Mobian just before that.
I'll reinstall Mobian.
Cheers!
He is right. There has been a lot of updates roll out in Mobian. It seems to be the most reliable right now with the modem and call handling.
Try this apn: ACCT.TF.GW6.VZWENTP
Here is a link to all the straight talk apn's for each network network/tower you may be trying to connect to.
https://internetapn.com/apn-settings/us/...s-verizon/
(02-21-2021, 11:14 PM)MtnSk8 Wrote: Try this apn: ACCT.TF.GW6.VZWENTP
It's AT&T not Verizon. Quite sometime back they changed the APN from tfdata to reseller. Using reseller absolutely works in my Android phone.
I got Mobian reinstalled and updated. Took the sim card out of my other phone, put it in the PinePhone, set the APN and it showed 4G with full bars. Started Firefox, navigated to a page and got "Server not found".
(02-23-2021, 11:23 PM)Barugon Wrote: I got Mobian reinstalled and updated. Took the sim card out of my other phone, put it in the PinePhone, set the APN and it showed 4G with full bars. Started Firefox, navigated to a page and got "Server not found".
You have to turn Mobile Data on via an on / toggle in the settings. Hopefully that works.
(02-24-2021, 02:21 AM)dcinoz Wrote: You have to turn Mobile Data on via an on / toggle in the settings. Hopefully that works.
Of course I did that. No go.
  4G VoLTE calls confirmed working with carrier x dcinoz 17 35,698 10-07-2025, 11:05 AM
Last Post: baptx
  MMS sending stopped working amindfv 7 7,358 05-04-2025, 01:36 PM
Last Post: zetabeta
  Modem crashes worsening from daily to multiple times a day + sms delaysFor people car bacydentir85 2 3,719 02-03-2025, 01:34 PM
  My new phone stopped working. gunnygee 3 4,398 12-12-2024, 01:21 PM
  Modem white list aular 7 6,316 02-13-2024, 04:35 PM
Last Post: aular
  qcell modem id aular 6 5,755 01-15-2024, 10:05 PM
Last Post: aular
  Temporary fix for Modem Not Coming Back on in SXMO Postmarketos Pinephone kebab 2 5,350 07-16-2023, 11:14 AM
Last Post: kebab
  Modem gets disabled on every suspend jojuma 5 6,623 03-27-2023, 02:51 AM
Last Post: jojuma
  Modem audio settings jack1 2 3,681 02-04-2023, 04:01 PM
Last Post: jack1
  Instructions to get pinephone working on USA carrier omarcomputing 1 4,058 10-08-2022, 04:45 PM
Last Post: treebeard
