Working modem?
I tried all the phosh distributions and couldn't get the modem to connect reliably. It would maybe show 3G and receiving calls/texts was questionable. I read about updating the modem firmware on the wiki page, found that my modem's firmware was out of date and updated it. Now it says that it connects 4G but I cannot access the internet at all (I haven't even tried calls/texts with the new firmware).
The rest of the phone works good enough for me to actually use it (even the camera works). I'd really like to use the pinephone but not having a working modem won't cut it. Any suggestions?
(02-14-2021, 10:17 PM)Barugon Wrote: I tried all the phosh distributions and couldn't get the modem to connect reliably. It would maybe show 3G and receiving calls/texts was questionable. I read about updating the modem firmware on the wiki page, found that my modem's firmware was out of date and updated it. Now it says that it connects 4G but I cannot access the internet at all (I haven't even tried calls/texts with the new firmware).
Did you set your apn?
(02-14-2021, 11:31 PM)rocket2nfinity Wrote: Did you set your apn?
Yes.
Yes.
Did you turn on Data in settings?
(02-15-2021, 09:54 PM)rocket2nfinity Wrote: Did you turn on Data in settings?
Yes.
Yes.
It sounds like your modem is working properly. My first thought is that your apn must be set wrong for your carrier. Worth the effort to check again. Or reset apn and restart phone.
(02-16-2021, 05:03 AM)rocket2nfinity Wrote: It sounds like your modem is working properly. My first thought is that your apn must be set wrong for your carrier. Worth the effort to check again. Or reset apn and restart phone.
It's just a single line for the APN setting, right? Or am I missing something?
Depends on your carrier/MVNO. Sometimes they specify specific ports, and text messaging has it's own fields to input.
This might be your problem https://forum.pine64.org/showthread.php?tid=12864
I saw this entry in the notes for the latest Arch Linux:
Quote:
  • Fixed USB Modem EMI (also requires latest modem firmware, see this)
So I installed it but now it doesn't see the sim card at all.
  4G VoLTE calls confirmed working with carrier x dcinoz 17 30,470 10-07-2025, 11:05 AM
Last Post: baptx
  MMS sending stopped working amindfv 7 6,072 05-04-2025, 01:36 PM
Last Post: zetabeta
  Modem crashes worsening from daily to multiple times a day + sms delaysFor people car bacydentir85 2 3,201 02-03-2025, 01:34 PM
  My new phone stopped working. gunnygee 3 3,667 12-12-2024, 01:21 PM
  Modem white list aular 7 5,129 02-13-2024, 04:35 PM
Last Post: aular
  qcell modem id aular 6 4,764 01-15-2024, 10:05 PM
Last Post: aular
  Temporary fix for Modem Not Coming Back on in SXMO Postmarketos Pinephone kebab 2 4,722 07-16-2023, 11:14 AM
Last Post: kebab
  Modem gets disabled on every suspend jojuma 5 5,312 03-27-2023, 02:51 AM
Last Post: jojuma
  Modem audio settings jack1 2 3,158 02-04-2023, 04:01 PM
Last Post: jack1
  Instructions to get pinephone working on USA carrier omarcomputing 1 3,427 10-08-2022, 04:45 PM
Last Post: treebeard
