Phoenix Card Is Not Showing Text
I'm trying to burn the RemixOS image but I get this empty window... I'm on Windows 10.
(05-06-2016, 04:14 PM)RaspiBit Wrote: I'm trying to burn the RemixOS image but I get this empty window... I'm on Windows 10.
Try running it as administrator. If that desnt work you can try running it in compatibility mode.
The latter should not be necessary. It runs fine on Win 10 without any compat. mode. Just wanted to add this.
I did the first but I get the same blank fields, I'll try the second.
Tried both with the same results [emoji24]
It's working on a native windows 7 pc, the problem comes from Windows 10. Any ideas please?
I'm trying to burn the lates RemixOS image but I'm getting this error :/
(05-07-2016, 03:59 AM)RaspiBit Wrote: It's working on a native windows 7 pc, the problem comes from Windows 10. Any ideas please?
This is not a PhoenixCard image. You should use Win32DiskImager instead for this image.
  How to boot from SD card on pinebook pro linux123 3 10,454 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 7,180 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 7,257 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 10,405 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 303,879 03-03-2020, 11:34 PM
Last Post: siyatalerja
  eMMC card on adapter Malmgren 8 19,058 03-20-2018, 11:14 AM
Last Post: Malmgren
  corrupt microsd card after reboot maxpayne 6 16,253 02-08-2017, 05:42 PM
Last Post: maxpayne
  recommended micro sd card? Gustavo Woltmann 1 6,190 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
  What is on the Micro SC card that came with the board? clawinus 1 6,171 11-03-2016, 02:33 PM
  SD card burn img size problems stephen0205 17 38,109 09-22-2016, 06:28 AM
Last Post: tkaiser
