UBPorts Not Working
I flashed the image to an SD card (https://ci.ubports.com/job/rootfs/job/rootfs-pinephone/), but when I load the card into the phone it won't start up. I used balenaEtcher-1.5.113-x64 to flash to the card.
PostMarketOS works.
Any thoughts?
(12-30-2020, 03:31 AM)Pinoideae Wrote: I flashed the image to an SD card (https://ci.ubports.com/job/rootfs/job/rootfs-pinephone/), but when I load the card into the phone it won't start up. I used balenaEtcher-1.5.113-x64 to flash to the card.
PostMarketOS works.
Any thoughts?
That link says it's depeciated and it also says you should use the image on this page instead https://ci.ubports.com/job/rootfs/job/ro...stemimage/
PostMarketOS works.
Any thoughts?
Thanks, that worked. Sound is not working though?
No sound for me either. I'm hoping the next kernel update fixes it.
(01-04-2021, 01:52 PM)neil_swann80 Wrote: No sound for me either.  I'm hoping the next kernel update fixes it.
I am getting sound, but it is so low to hear very well
I imaged a new OS to SD card and the sound works, but it's very soft, too.
I'm trying to flash but when I boot I just get either a red light and no display or a Pine64 logo and it stays there (depending on if I hit power or plug in USB).
Does anyone else see this power-on issue? How long is initial boot?
Regarding the volume being too low, it could be related to https://gitlab.com/postmarketOS/pmaports/-/issues/926
(03-13-2021, 10:05 AM)bujiraso Wrote: I'm trying to flash but when I boot I just get either a red light and no display or a Pine64 logo and it stays there (depending on if I hit power or plug in USB).
I would try using Etcher for the image.
Also after an update, the OS no longer can connect to the cell system of my provider. I know it is not hardware issue, as booting up Manjaro now connectsa to the provider. For a long time, I had an issue with manjaro connecting for a few seconds, then forever disconnecting.
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 11,571 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
  Nextcloud Account setup not working kelbot 3 11,245 04-21-2021, 11:25 AM
Last Post: lsitongia
  online accounts in UBports Uturn 2 7,285 03-30-2021, 09:12 AM
Last Post: Uturn
  If you're ready to tinker - here is how to get the more features working right now Luke 17 48,846 01-09-2021, 12:14 PM
Last Post: Csanderson0313
  How to enable Ethernet with UBPorts and convergence dock? piney-tim 1 5,088 11-27-2020, 07:40 PM
Last Post: piney-tim
  UBPorts Convergence MonCon 0 3,877 11-24-2020, 04:25 PM
Last Post: MonCon
  Looks like I found a mild reason why UBPorts for pinephone hasn't seen much progress. plainenough 13 28,437 11-21-2020, 06:30 PM
Last Post: Nooblife
  "No network" on new UBPorts community edition pinephone professorsnapper 6 13,645 10-19-2020, 10:27 PM
Last Post: htc_tattoo
  UBPorts doesn't boot even after booting into recovery defekto 2 7,705 09-30-2020, 12:16 PM
Last Post: defekto
  Pinephone 3G Bluetooth Working Pretty Well With Latest Mobian Updates rmcg 0 4,207 09-27-2020, 10:22 PM
Last Post: rmcg
