PineTab Mobian
(11-25-2020, 08:07 AM)guenther Wrote:
(11-18-2020, 06:21 AM)guenther Wrote: folks, does bluetooth work on your pinetab (mobian)? Mine is dead since first mobian image...
Someone please! The "settings" app tells me "no bluetooth found" and I just want to know if it's an HW or SW issue...
I can confirm, bluetooth does not work on my PineTab with mobian. I can't swipe the little switch from grey to blue. It says no bluetooth found.
I have used lshw and it doesn't list a bluetooth device, so it looks like it isn't supported yet.
Thank You @ichbins and @n3rDy for clarifying. What made me wonder is that AFAIK BT works on the PinePhone what uses the same Wifi Chip. My old Belkin USB BT Stick is recognized also. Anyway, if it's SW related, I'm OK with that.
Screen resolution in landscape mode was not correct recognized. Most apps sclae like on portrait. Even when the orientation is landscape. And in settings it is not changeable. It remains on portrait
Internal bluetooth doesn't work. I inserted a USB bluetooth dongle, however, and that works fine (at least for audio -- I haven't tried anything else).
(11-26-2020, 07:52 AM)firefox-58 Wrote: Screen resolution in landscape mode was not correct recognized. Most apps sclae like on portrait. Even when the orientation is landscape. And in settings it is not changeable. It remains on portrait
No, should work. Have you flashed the latest build,at least 20201113 ? Is it "docked"?  I can confirm that settings have no effect on orientation, but the button on the top works.
(11-26-2020, 05:30 AM)guenther Wrote: Thank You @ichbins and @n3rDy for clarifying. What made me wonder is that AFAIK BT works on the PinePhone what uses the same Wifi Chip. My old Belkin USB BT Stick is recognized also. Anyway, if it's SW related, I'm OK with that.
Bluetooth works with mobian on my PinePhone and on my PineTab it does not work.
Yes, for some reason BT doesn't work on the PineTab, I still need to find time to debug this.
(11-27-2020, 03:25 AM)a-wai Wrote: Yes, for some reason BT doesn't work on the PineTab, I still need to find time to debug this.
I'm not a developer, so I'm not sure if this makes a difference but internal BT doesn't work. My BT dongle does work.
(11-27-2020, 08:07 AM)Baslow Wrote: I'm not a developer, so I'm not sure if this makes a difference but internal BT doesn't work. My BT dongle does work.
Yes, this was a device tree issue, as the internal wifi wasn't properly declared, "generic" BT functionality always worked fine.
(note the use of "was" in the above sentence Wink )
  New Pinetab- error when attempting to install updates authorjaw 1 1,207 02-26-2026, 01:21 AM
Last Post: Raik
  Mobian OS stefan_hdb 1 3,094 04-08-2025, 09:14 AM
  PineTab (early adopters) wifi broken in kernel 6.12 bartgrefte 0 2,110 03-23-2025, 05:25 AM
Last Post: bartgrefte
  Where to find older Mobian image? guenther 2 2,944 10-30-2024, 02:50 AM
Last Post: guenther
  PineTab 2 login screen rotation fix chzbacon 11 17,858 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 7,809 02-24-2024, 12:29 PM
Last Post: Evergreen
  [PineTab2] Issues with Mobian Networking Cornelia Xaos 7 10,553 12-30-2023, 10:02 PM
Last Post: Cornelia Xaos
  Mobian Boot Problem rogerwegmann 14 16,556 12-13-2023, 11:04 AM
Last Post: diederik
  Working OS on pinetab RISC-V? user641 3 4,946 12-13-2023, 08:11 AM
  Mobian won't boot after ton of updates bartgrefte 11 15,654 12-10-2023, 02:47 AM
