No sound from rockpro64 audio jack.
Hi, i am using ubuntu18LTS on my rockpro64.
uname -a
Linux rockpro64 4.4.138-1097-rockchip-ayufan-gb5128c0a1684 #1 SMP Sat Sep 29 15:08:06 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
default:CARD=rockchipes8316c
    rockchip,es8316-codec,
    Default Audio Device
sysdefault:CARD=rockchipes8316c
default:CARD=rkhdmidpsound
    rk-hdmi-dp-sound,
sysdefault:CARD=rkhdmidpsound
    rk-hdmi-dp-sound,
It looks like there is audio driver but still not able to hear any sound from 3.5mm audio jack.
Also i tested with a simple flite based command line text to speech test-
flite -t hello
It throws error-
audio_open_alsa: failed to set hw parameters. Invalid argument.
As note-
mplayer test.mp3
MPlayer 1.3.0 (Debian), built with gcc-7 © 2000-2016 MPlayer Team
do_connect: could not connect to socket
connect: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing test.mp3.
libavformat version 57.83.100 (external)
Audio only file format detected.
Clip info:
Title:
Artist:
Album:
Year:
Comment: converted by convert2mp3.net
Genre: Unknown
Load subtitles in ./
Opening audio decoder: [mpg123] MPEG 1.0/2.0/2.5 layers I, II, III
AUDIO: 44100 Hz, 2 ch, s16le, 192.0 kbit/13.61% (ratio: 24000->176400)
Selected audio codec: [mpg123] afm: mpg123 (MPEG 1.0/2.0/2.5 layers I, II, III)
AO: [pulse] 44100Hz 2ch s16le (2 bytes per sample)
Video: no video
Starting playback...
A: 11.2 (11.1) of 2340.0 (39:00.0) 0.7%
MPlayer interrupted by signal 2 in module: play_audio
A: 11.3 (11.2) of 2340.0 (39:00.0) 0.7%
mpv test.mp3
Playing: test.mp3
(+) Audio --aid=1 (mp3 2ch 44100Hz)
File tags:
AO: [pulse] 44100Hz stereo 2ch s16
A: 00:00:13 / 00:39:00 (0%)
Exiting... (Quit)
It seems song is being played but no sound,
Any suggetion?
Hi, it seems quit a long time.
Any suggestion will be appreciated
I am running Android 9 on RockPro and also would like to use my audio jack output. Any ideas how to set it in RetroArch?
  RockPro64 automatically run after power recovery - my solution g2t 1 1,839 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 4,525 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,856 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,599 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 4,810 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,327 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,985 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 14,067 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 5,276 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 6,676 04-06-2023, 02:46 PM
