Pinephone 64 PostMarketOS edition Battery problem
Hello everybody, first of all, nice to start in this amazing mobile project and say hello to the community.
I were trying to use PinePhone64 since I received it (more than 10 days), at the begging the battery where charging to 100%, but the mobile where losing the charge "fast". I supposed that it was about the PostMarketOS edition or updates; but right now the battery doest charge more than 30% and when I connect and disconnect the phone from charge, the OS shows me different percents of battery charge status. Anybody known what can happen and how to solve it?
Thanks in advance, thanks a million for your time.
(11-08-2020, 08:10 PM)Alejandro.SU Wrote: Hello everybody, first of all, nice to start in this amazing mobile project and say hello to the community.
You may have a defective battery. The Samsung J7 battery, as listed in the wiki, is easy and cheap to obtain in most places locally.
(11-09-2020, 12:25 AM)rocket2nfinity Wrote: You may have a defective battery.
+1. If you can get your hands on a J7 battery, see if the same symptoms manifest.
Regardless, try contacting Support for an RMA.
(11-09-2020, 12:25 AM)rocket2nfinity Wrote: You may have a defective battery. The Samsung J7 battery, as listed in the wiki, is easy and cheap to obtain in most places locally.
It is impossible to decide whether it is the battery or the charging circuitry or the software.
He can test the hardware by installing the postmarket factory test build on an SD card and booting it. But the fact he is able to run an OS, and the battery varies wildly, plus no charge over 30 when he was getting 100 indicates it's most likely the battery, not the hardware or OS.
Please explain to an engineer:
How should the factory test image allow to decide whether it is a defective battery or power management circuitry???
I could observe that when I extract the charger from the mobile, after a considerably time charging (when is connected in the computer or by using usb or normal mobile charger on a plug) that the OS changes automatically the battery's percent up or down, so I think that the problem can be the battery or the connector... I am not sure. Thanks to everybody for your help.
It's worth checking the connectors on the ribbon between the main board and the USB board are properly seated. One of mine wasn't, although it was working properly, and I think there was at least one report of someone finding that reseating one of the connectors sorted a battery problem. I'd trust 'cat /sys/class/power_supply/axp*/uevent' over the desktop indicator.
Thanks for you answer! I will try to do it. Regards!
I received few days ago a new battery and the problem persist, with this battery is even worst (j7 battery), I tryed the commands that @wibble posted and shoes everything ok.. I expended time and money on support this proyect.. my intention was code some software to manage the phone agend... it means that I dont have a waranty to can change the phone that works returning the defective one? In the moment that I bought this post market version I readed that waranty doesnt voer dead pixels on screen but its is not my case, I will be very grateful if I can change the phone.
  Freezing and force rebooting on PinePhone HHawks 4 4,256 05-02-2025, 09:04 AM
Last Post: HHawks
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 3 7,200 11-18-2024, 02:23 AM
Last Post: linmob
  [Not Pinephone] Phosh Autologin LienRag 11 12,411 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  How to include desktop file and icon in a postmarketos package patrickMcDonald 0 3,080 07-27-2023, 12:34 PM
Last Post: patrickMcDonald
  Battery issues user641 3 6,182 07-17-2023, 10:43 AM
Last Post: alaraajavamma
  installed postmarketos v23.06 no audio samlo 1 4,168 07-14-2023, 12:53 AM
Last Post: samlo
  Scanning with PostmarketOS AndyM 1 3,745 07-01-2023, 08:16 AM
Last Post: AndyM
  VPN for PostmarketOS publiclewdness 1 4,830 03-11-2023, 04:35 PM
  Boots To Shell After Dead Battery (PMOS) britelite 0 2,425 02-17-2023, 02:41 PM
Last Post: britelite
  Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue X0X0X0X0X0 1 4,693 02-11-2023, 08:19 AM
Last Post: acid andy
