Howto: OctoPrint Working on Pine 64
#21
(10-28-2020, 03:02 PM)macstibs Wrote: [quote pid='81368' dateline='1603276080']
any chance of getting the webcam.zip?
Just as an FYI - The DietPi image for Pine64 has an installable list of software which includes a version of OctoPrint.  Once it's up and running, it will offer you an update to 1.3.4 or whatever the latest is.
Unfortunately, the webcamd package that's listed is also offline and I haven't had a chance to locate/install a substitute yet.
totilolmomanon
(12-04-2016, 06:38 PM)dabone Wrote: I put together an image for a 4gb card with octoprint along with the curaengine, and the ability to restart, reboot, or power off the pine from the web interface.
Octopine 12-04-16 Release
Just download it, write out to your favorite 4gb or greater card, and then login in using pi / raspberry.
The run
sudo resize_rootfs.sh
reboot
I used the pi user name, in hopes that it will be able to update via the web interface.
pi user can sudo without any password now.
Curaengine is installed, along with camera support.
Edit 12-9-16... Updating from Octoprint works!
set the checkout folder to
/home/pi/OctoPrint
Later,
dabone
Unfortunately your link isn't live anymore. Any chance I could get ahold of that file?
[/quote]
Where can I find the webcam.zip file?
I'm trying to get a Filament-Sensor working on my rock64 with armbian installed and octoprint. Any help? Gpio Kris saying failed not a pi device.
Guess I'll be figuring this out soon as I have my first 3D printer on the way and several PINE devices vs 0 Rpis.
EDIT: gues it's time. Going to probably do a couple of test prints with my fedora notebook and then connect something with wifi to it (I wonder if I can get the H64 to do this well? limited OS options but it's a nice board in terms of specs)
it doesn't get happy
it doesn't get sad
it just runs programs
  Debian installer on Pine A64+ but no hdmi mrwick 1 9,277 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Captive portal at school not working on the Pinebook pro WilliamZieg 2 8,327 02-06-2020, 10:41 PM
Last Post: xmixahlx
  Q4OS WiFi Dongle not working cheezmeister 3 8,354 04-07-2017, 08:01 AM
Last Post: iccoldbeer
  HowTo working with MPD and analog sound caragk 3 17,377 11-09-2016, 08:44 AM
Last Post: jkmooney
Exclamation JAVA App. not working correct wrongway 0 3,782 09-14-2016, 11:14 AM
Last Post: wrongway
  Anyone got jackd working? jkmooney 4 10,432 08-27-2016, 08:18 AM
Last Post: pfeerick
  32bit Apps on Pine djinn5150 2 7,337 08-09-2016, 11:03 AM
Last Post: xalius
  Can ping between Pine 64 on a switch, but unable to ssh MikeJewski 4 10,189 07-28-2016, 08:40 PM
Last Post: MikeJewski
  Internet not working properly cezar.suteu@gmail.com 2 7,208 06-17-2016, 01:12 AM
Last Post: cezar.suteu@gmail.com
  wget not working? slerched 3 9,495 06-01-2016, 08:15 AM
Last Post: slerched
