An unofficial Fedora Installer for Pinebook Pro
I made an installer script for Fedora on Pinebook Pro. For now I am using Manjaro kernel. I have done a lot of testing, but comment, issues and PRs are welcome.
https://github.com/bengtfredh/pinebook-p...taller.git
Thanks for the script. I just used it to set up my pbp cause there is no official release till now. Running smooth, only the sound is horrible. Is there a patch missing to fix the sound issue?
(10-15-2020, 12:02 PM)stoelpi Wrote: Thanks for the script. I just used it to set up my pbp cause there is no official release till now. Running smooth, only the sound is horrible. Is there a patch missing to fix the sound issue?
I am happy you like it. The sound is horrible, to be honest I have not looked in to it. I am working on a copr repo to make the image more fedorish. But check out this thread https://github.com/smithmcgriff/Fedora-o...o/issues/7. Try what @westurner writes in first post.
Thanks, with alsamixer I could adjust the sound. Do you know more about upcoming official support of the pbp, I didn’t find any definite statements?
(10-18-2020, 05:44 AM)stoelpi Wrote: Do you know more about upcoming official support of the pbp, I didn’t find any definite statements?
Official support is coming soon in Fedora 33, according to the fine folks from #fedora-arm@freenode.net .
Yes I also read this on the arm mailing list. Looking forward on it!
Awesome :-)
Awesome :-)
I did use the script to install fedora on an SD card. On my emmc I am running the original fedora 32 gnome image updated to 33 but still running the 5.7 kernel. Initially I tried to install fedora 33 with the install script but that failed (seem like this might be fixed) so installed fedora 32 and updated to 33 and installed the pbp-kernel (5.9.8).
wds@pinebookpro01 ~$ uname -a
Linux pinebookpro01 5.9.8-1 #1 SMP Tue Nov 17 14:41:35 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux
Still need to run through a bunch of test especially suspend which I do not believes works.
This is what I have installed from the copr:
wds@pinebookpro01 ~$ dnf repository-packages copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro list
Fedora Modular 33 - aarch64 - Updates        78 kB/s |  14 kB    00:00
Fedora 33 - aarch64 - Updates        86 kB/s |  13 kB    00:00
Fedora 33 - aarch64 - Updates        721 kB/s | 1.4 MB    00:01
Installed Packages
ap6256-firmware.aarch64        2020.02-5.fc33        @copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
kernel-pbp.aarch64        5.9.8-1.fc33        @copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
kernel-pbp-core.aarch64        5.9.8-1.fc33        @copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
kernel-pbp-modules.aarch64        5.9.8-1.fc33        @copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
pbp-keyboard-hwdb.aarch64        20200629-1.fc33        @copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
pinebookpro-audio.aarch64        2-1.fc33        @copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
pinebookpro-network.aarch64        1-1.fc33        @copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
pinebookpro-suspend.aarch64        2-4.fc33        @copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
Available Packages
ap6256-firmware.src        2020.02-5.fc33        copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
kernel-pbp.src        5.9.8-1.fc33        copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
linux-manjaro.aarch64        5.9.6-1.fc33        copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
linux-manjaro.src        5.9.6-1.fc33        copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
pbp-keyboard-hwdb.src        20200629-1.fc33        copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
pinebookpro-audio.src        2-1.fc33        copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
pinebookpro-extlinux.aarch64        1-1.fc33        copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
pinebookpro-extlinux.src        1-1.fc33        copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
pinebookpro-network.src        1-1.fc33        copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
pinebookpro-suspend.src        2-4.fc33        copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
uboot-pinebookpro.aarch64        2020.10-1.fc33        copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
uboot-pinebookpro.src        2020.10-1.fc33        copr:copr.fedorainfracloud.org:aptupdate:pinebook-pro
Awesome :-)
Installed Packages
Available Packages
Hi there,
I've installed Fedora with this howto (https://github.com/bengtfredh/pinebook-p...taller.git) on a 16GB SD-Card. I've also a fedora installation on the EMMC (https://builds.armdevelopers.com/pineboo...pro.img.xz). The Pinebook-Pro always boot from EMMC, I think the SD-card-Image isn't working on my laptop.
If I update my working EMMC-Image with kernel-pbp.aarch64, laptop is booting fine, but I have to leave the original (5.7) kernel. Otherwise the laptop can't boot anymore.
@aptupdate: How can I get a working Fedora from your howto?
Andreas
(07-25-2020, 12:41 PM)aptupdate Wrote: I made an installer script for Fedora on Pinebook Pro. For now I am using Manjaro kernel. I have done a lot of testing, but comment, issues and PRs are welcome.
Hello aptupdate
thank you very much for these prebuild images https://s3.fredhs.net/minio/pinebook-pro-image/
Thats exactly what I'm looking for. Now I'm in the process to rebuild my Pinebook Pro with your image !
Next week I take your image and try to modify it for booting my Helios64 NAS-Device (it's based on the same processor and network card).
Andreas
  Boot Order in Pinebook Pro food 12 18,252 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,161 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,054 08-09-2025, 06:53 AM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,401 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,620 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,257 03-31-2024, 10:11 AM
Last Post: u974615
  Fedora 37 installation gswatkins 16 19,977 03-16-2024, 03:09 PM
Last Post: michel_luc
  Pinebook Pro upgrading from the factory image yamsoup 12 17,314 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,163 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,346 12-11-2023, 03:47 AM
Last Post: calinb
