No Connection to Carrier from Pinephone 3G Model
OK I reflashed the Modem Firmware:
It was successfull
[034.898]: THE TOTAL DOWNLOAD TIME IS 29.555 s
[034.898]: Upgrade module successfully.
But the problem is still the same:
No connection to carrier!!!
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: ===================================================
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Version: RPMR07A03_1:37500: Dec 2 2019
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Version: TZR07A03: Dec 2 2019
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Version: SBLR07EG25G01_1:37500: May 30 2
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Build Date: 2020-06-13,09:14
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Custom Name : STD
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Branch Name: 9x07_R07_NEW
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Project Rev : EG25GGBR07A08M2G_01.002.07
Okt 23 09:55:44 alarm kernel: modem-power serial1-0: Project Name: EG25G
Okt 23 09:55:43 alarm kernel: modem-power serial1-0: ===================================================
I only get this:
Okt 23 09:55:52 alarm ModemManager[3780]: <warn> [modem0] couldn't load supported assistance data types: LOC service: general failure
Okt 23 09:55:51 alarm ModemManager[3780]: <warn> [modem0] couldn't load list of own numbers: Couldn't get MSISDN: QMI protocol error (16): 'NotProvisioned'
Okt 23 09:55:51 alarm ModemManager[3780]: <warn> [modem0/sim0] couldn't load list of emergency numbers: uninitialized emergency numbers list
Okt 23 09:55:51 alarm ModemManager[3780]: <warn> [modem0/sim0] couldn't load operator name: Couldn't get home network: QMI protocol error (16): 'NotProvisioned'
Okt 23 09:55:51 alarm ModemManager[3780]: <warn> [modem0/sim0] couldn't load operator identifier: Couldn't get home network: QMI protocol error (16): 'NotProvisioned'
And if I search for the network in phosh manualy this:
Okt 23 09:57:28 alarm gnome-control-c[3945]: Error: scanning networks failed: Zeitüberschreitung wurde erreicht
Okt 23 09:57:42 alarm ModemManager[3780]: <warn> [modem0] couldn't load operator name: Current operator description is still unknown
Okt 23 09:57:42 alarm ModemManager[3780]: <warn> [modem0] couldn't load operator code: Current operator MCC/MNC is still unknown
From my side it's not an Error with the firmware.
Currently I tried 3 different SIM Cards,
and wrote the whole firmware to the modem.
I think the Modem is broken somehow.
(10-23-2020, 04:24 AM)merlin Wrote: OK I reflashed the Modem Firmware:
It was successfull
I only get this:
This may seem simple, but have you checked the connections to the antenna and looked for anything on the circuit board that may not be right - i.e. loose/overtight screws, a spec of solder somewhere or not where it should be? Something amiss with the sim card tray? It seems the modem is functional but just isn't connecting.
It was successfull
I only get this:
I didn't open the device until now.
I tested around with AT commands (first time trying this).
I wrote a library in python to have a simple AT Commandline.
The sim is correctly connected, I could read out the  ID of the SIM:
--> AT+QCCID
<-- +QCCID: 89120000.....
Reception power is really low:
--> AT$QCSQ
<-- $QCSQ :-91,-2,0,0,-93
Tomorrow I'ill take a screwdriver and have a look at the antenna.
Yes, that simply was it.
The connector was lying next to the plug Huh
So easy could a problem be solved.
(10-24-2020, 09:53 AM)merlin Wrote: Yes, that simply was it.
WOW this is good to know!!
Glad to see you found and fixed the problem !
This is something that could be useful to other users.
Thanks to your persistence  !
Hi @merlin
I have the same problem as you, I opnened the PinePhone but I could not distinguish if the wire is connectes or not... Do you have a photo of the part of the phone I have to look at?
Thanks in advance!
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 24,365 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 16,351 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 26,754 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,750 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,230 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,853 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,825 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,442 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,526 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 4,050 03-25-2025, 08:51 PM
