How to flash modebian to emmc
How do I flash the modebian image to the emmc on the pinephone?
(10-17-2020, 11:41 AM)maybl8 Wrote: How do I flash the modebian image to the emmc on the pinephone?
Flash the Jumpdrive 0.5 on your SD. Insert the SD in your PP and turn it on. You'll see an image of Jumpdrive and connect your cable with your Laptop/pc. Now your PP (Emmc) will be mounted. Select the emmc to flash your image. Good luck!
Link Jumpdrive: https://github.com/dreemurrs-embedded/Ju...e/releases
Check out https://wiki.pine64.org/index.php/PinePh...structions and try with jumpdrive.
Verstuurd vanaf mijn Wileyfox Swift met Tapatalk
Ok I got this. Thanks for the help.
I have to flash the jump drive to a sdcard .
Boot to the sdcard.
Then I can flash the image from my computer hard drive to the emmc.
Then I can take out the sdcard and it boots to the emmc.
I decided to use the modebian image because it actually works with my phone.
I can make and receive calls and use the internet .
I have a t-mobile sim that works with the phone.
(10-17-2020, 01:29 PM)maybl8 Wrote: Ok I got this. Thanks for the help.
Boot to the sdcard.
Yes
Exclamation Cannot flash the modem firmware anonymous 9 13,934 12-17-2025, 01:42 AM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 11,384 11-22-2023, 11:46 AM
Last Post: aLoop100o
  [Megapixels] Flash strobe, pictures viewer and MPCamera error 22 freelectro 1 4,071 08-30-2023, 03:59 AM
Last Post: karensather
  ModemManager debug mode? (Needed to flash modem) calinb 1 5,932 02-27-2023, 04:18 PM
Last Post: calinb
  Lot of issues after flashing mobian to emmc with tow-boot benedikt55 5 8,118 08-30-2022, 01:14 PM
Last Post: benedikt55
  DDing mobian to emmc or microSD not starting... Mr.Berzerk 2 4,077 08-05-2022, 06:09 PM
Last Post: mark1250
  How to flash a µSD-Card with Balena Etcher walter1950 1 3,589 01-22-2022, 02:06 AM
Last Post: bcnaz
  Suddenly, nothing but a backlight and a boot logo flash 3x5co 8 9,727 12-05-2021, 08:24 PM
Last Post: Anna
  More weirdness when booting from eMMC Zebulon Walton 2 4,164 10-27-2021, 07:06 PM
  Modem suddenly not enabled when booting from eMMC Zebulon Walton 3 6,288 10-23-2021, 01:55 PM
