Is the PinePhone compatible with UHS-II or UHS-I Micro SD?
Just wondering is it worth buying a faster Micro SD card for a PinePhone Community Edition so it may run a bit faster?
The quicker cards tend to be USH-III then USH-II then USH-I:
https://www.androidcentral.com/best-micr...rd-android
If your device is only capable of dealing with USH-I devices then if you plug in a USH-II device then it will run at USH-I speeds.
https://havecamerawilltravel.com/photogr...osd-cards/
Here it says that for the Rock64 it probably supports USH-I but not any higher:
https://forum.pine64.org/showthread.php?tid=4685
The user manual says UHS1.
I can confirm the Samsung EVO Select 128GB microSDXC UHS-I U3 works perfectly in my postmarketOS Community Edition with the convergence package. Everything I've tried so far feels quite snappy for an SD card. I would recommend going no lower than 128GB, though, as the product description states:
Quote:¹4K UHD video support for 51GB, 256GB and 128GB cards.
I imagine "51GB" should be "512GB".
(09-19-2020, 08:18 AM)5432h90asfd Wrote: Just wondering is it worth buying a faster Micro SD card for a PinePhone Community Edition so it may run a bit faster?
See this post and this comparison then buy a saumsung evo plus card.
Really helpful. Muchas Grascias.
Note that Samsung Evo+ and Samsung Evo Plus are two different cards. The Evo+ is no longer manufactured, and the Evo Plus is not as good at random IOPS (around 60-75 % of the performance of the Evo+; see this comparison)
An alternative that looks good is "SanDisk Extreme 100MB/s UHS-I U3 V30 A1 32GB microSDHC" (SDSQXAF-032G-GN6MA), see this review.
  Pinephone + Keyboard for sale, little use ruemoo 17 12,703 08-04-2026, 06:27 PM
Last Post: greebleshaver
  Pinephone - broken power button rorus 14 24,387 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 1,812 01-20-2026, 01:43 PM
Last Post: Anna
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 20,557 12-12-2025, 03:27 AM
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 8,129 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 3,410 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 2,649 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 6,078 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 4,407 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 3,227 03-25-2025, 08:51 PM
