Mobian on SD Card or Flashed To eMMC For Better Functionality . . .
I have the PMOS edition and feel somewhat loyal to them, bc their name and logo is on the back of my phone. The problem is I find myself playing with Mobian 90% of the time. When I make calls, Mobian booted from an SD, people say they can hear me but not that clear. I'm curious would a difference be made if I were to flash Mobian directly onto the phone and not use it through the SD Card ? Or does it really not matter the phone will behave as it does either way.
I have the PMOS based phone.
Mobian does make a difference.
Your phone will function pretty much the same running from the sd cards as from the eMMC.
But it will feel a little bit  'snappier'  once you do install the system on the eMMC...
       ie: the apps will open a bit quicker.
  Meanwhile the sd cards do make it much easier to  'test drive' the different operating systems,
    rather than installing each onto your eMMC.
Once you decide on which operating system you want permanently and install that to your eMMC.
Then you can use your sd card for extra storage.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(09-14-2020, 07:03 AM)NobodyNew1 Wrote: Hello,
If the specification of your SD-card shows decent speed for reading and writing (e.g. UHS-1) there won't be a noticeable difference in speed.
I will keep the original pmOS until the one on the card is stable enough.
  pinephone-support package not upgradable on Mobian fhireman 5 9,250 02-28-2026, 05:49 PM
Last Post: baptx
Exclamation No wIfI after Mobian update crakabeats 5 8,816 02-28-2026, 04:18 PM
Last Post: baptx
  What is wrong with the Mobian signature key? Mahgue 0 1,815 11-08-2025, 05:13 AM
Last Post: Mahgue
  Clamares password needed with new Mobian installation fauvetan 1 3,420 06-26-2025, 03:00 AM
Last Post: merom
  install iso from sd card to emmc aular 2 4,214 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,949 01-09-2024, 07:02 PM
Last Post: britelite
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 15,405 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 35,541 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  SD Card has wrong capacity AndyM 11 11,258 06-11-2023, 12:30 AM
Last Post: AndyM
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 9,049 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
