Clamares password needed with new Mobian installation
I just try to install Mobian on my Pinephone using the dd’s method but when I put the SD card inside the phone and try to boot on it, I get the “Enter disk decryption passphrase” of Clamares. I read that “1234” is the default password, but it doesn’t work. Clamares tell me it’s a wrong password.
I flashed my sd card many times, trying some tweeks, but the message still the same.
So, what can I do to bypass this situation?
Thank you.
(06-25-2025, 03:01 PM)fauvetan Wrote: Hello,
Thank you.
Hi, in my opinion, you should first install the Tow-Boot. This allows easy access to the Pinephone internal memory.
Depending on what you write, Calamares calls you on creating a new password. Create some password that you will enter when you start your mobile. The password must be longer, about 8 or more characters.
This 1234 is for the user login, not for installation using Calamares.
  pinephone-support package not upgradable on Mobian fhireman 5 8,012 02-28-2026, 05:49 PM
Last Post: baptx
Exclamation No wIfI after Mobian update crakabeats 5 7,855 02-28-2026, 04:18 PM
Last Post: baptx
  What is wrong with the Mobian signature key? Mahgue 0 1,419 11-08-2025, 05:13 AM
Last Post: Mahgue
  Default password for KDE plasma pine phone Toni 0 8,261 09-14-2025, 06:35 PM
Last Post: Toni
  What is leaked as installation ? LienRag 10 12,709 03-08-2025, 11:47 AM
Last Post: LienRag
  Turn off password reginaborder 2 3,408 07-04-2024, 01:53 AM
Last Post: Gumur
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 14,442 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 33,588 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  The Pinephone pro does not turn on and installation of the OS Alexander27 1 2,641 09-25-2023, 02:34 PM
  rough estimate of expected microSD installation life? andrewp907 7 9,081 06-10-2023, 07:55 PM
