looking for pandoc binary for pinebook pro
I installed manjaro on my PBP, and am very happy with it. But I really need pandoc in order to make it my daily driver, and manjaro does not have pandoc in their repos for arm64. So I thought I would ask people running different distros to check and see if pandoc is available from their respective repos and indicate yes or no in a reply? Any help or suggestions are much appreciated, and I would add that pandoc on my pinephone would be awesome too.
Thanks.
According to their site (https://pandoc.org/installing.html#linux) it's unlikely you'll find it. It appears they only offer support for x86 platforms.
(08-25-2020, 07:15 AM)tophneal Wrote: According to their site (https://pandoc.org/installing.html#linux) it's unlikely you'll find it. It appears they only offer support for x86 platforms.
This link https://www.reddit.com/r/linuxquestions/...andoc_arm/ suggests it is available from the standard repos in the debian distro. I will try that and report back here.
(08-25-2020, 07:22 AM)codebreaker Wrote: This link https://www.reddit.com/r/linuxquestions/...andoc_arm/ suggests it is available from the standard repos in the debian distro. I will try that and report back here.
Just stumbled upon this issue: https://github.com/jgm/pandoc/issues/5450 and it looks like some have started provided aarch64 binaries. I was wrong, my bad.
So I created pkgbuild files to package pandoc and pandoc-citeproc for Manjaro (Arch) on the pinebook pro. The repository is here:
https://github.com/cbrown1/pandoc-arm64
Awesome, glad you were able to make it happen! You should submit your pkgbuild to the AUR, too!
Thank you so much, this was a real problem on PBPs ! I second tophneal : that would be even more convenient for everyone if the pkgbuild was on the AUR.
  Window Maker Live for Pinebook Pro vajak 1 250 12-10-2025, 05:19 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 12,115 08-09-2025, 06:53 AM
Last Post: Sb2024
  Boot Order in Pinebook Pro food 11 10,611 03-28-2025, 10:08 AM
Last Post: DrYak
  Pinebook pro won't boot after bootloader installation jwensouls 4 5,635 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,091 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 8,779 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 11,607 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 7,305 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 8,405 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 136,190 12-08-2023, 11:25 PM
