Flash new OS on Pinephone?
Obviously a useful feature. I have a micro SD plugged in with Arch flashed on it. How do I install arch?
(09-02-2020, 04:53 PM)Potts Wrote: Obviously a useful feature. I have a micro SD plugged in with Arch flashed on it. How do I install arch?
Never-mind I am a dingus. However I won't delete this in the hopes it may help someone out...
Insert your SD card in the top slot not the bottom!
[EDIT]
It now seems that OS's that I am trying to install are not booting properly. When an image is flashed with etcher and inserted (in the top) card slot, the OS should boot on launch, correct? Currently the screen stays black and a red light appears at the top left hand of the device.
The Wiki explains most things like this: https://wiki.pine64.org/index.php?title=..._Jumpdrive
Most people prefer to flash to SD card first unless you're committed to the one OS. With a good quality SD card, you probably won't notice much difference in performance. Flashing to SD is quicker than flashing to eMMC. I'm not sure there is a way to install from SD to eMMC. I imagine the Wiki method is best.
Good luck.
Edit: I just saw your update. That's a better way to get it working. I'll leave that info above just in case someone is unsure.
  asterisk or FreePBX on pinephone? vanja 0 993 06-16-2026, 09:24 AM
Last Post: vanja
  Jami on Pinephone [ IM and VOIP ] p1trson 15 25,841 06-16-2026, 05:02 AM
Last Post: marlboro1950
  Movuan distribution for PinePhone merom 6 8,308 06-04-2026, 02:10 AM
Last Post: merom
  Latest firmware for PinePhone modem! Subsentient 106 249,729 04-03-2026, 08:37 AM
Last Post: baptx
  Fedora + Phosh for PinePhone njha 77 236,179 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,487 11-17-2025, 07:49 AM
Last Post: danm1988
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 4,858 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 73,034 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 6,314 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 83,335 07-26-2024, 10:35 PM
