u-boot (forks) status
(10-14-2019, 12:50 PM)ayufan Wrote: I'm now working on switching to mainline u-boot for all my distros and to provide exact same functionality. Seems fairly doable Smile
Hello @ayufan. Any updates about this?
@XmAz, unfortunately I have not been able to get a mainline U-Boot build working.
(08-08-2020, 12:05 PM)CameronNemo Wrote: @XmAz, unfortunately I have not been able to get a mainline U-Boot build working.
@ayufan did begin updating his images with mainline uboot. It might be worth looking to see what ROCK64 imgs he's updated in the last 6mo.
False alarm on my side actually... finally set up the serial console and discovered it was a kernel issue, U-Boot 2020.07 and ATF 2.3 work fine here using the open source SPL/TPL.
simonsouth
Quote:I'll write up a lengthier tutorial when I'm done but to start using the mainline version of U-Boot, assuming you have the prerequisites taken care of (the cross-compilation toolchain installed if needed, the ARM Trusted Firmware BL31 built and the CROSS_COMPILE and BL31 environment variables set appropriately), you'll need to ....
Thanks, simonsouth, for your primer.  Looking forward to the lengthier version if you ever find time.
I want to boot a efi_stub enabled kernel, and this 2017 u-boot doesn't know the "efidebug" command, which is necessary, according to these instructions.  Your tutorial is encouraging enough to proceed to try and build and upgrade u-boot.
  Rock64 v2.0 u-boot SPI issues ju0n 1 1,574 09-25-2026, 11:19 PM
Last Post: mysy
  Rock64 won't boot luminosity7 10 19,554 03-16-2024, 08:33 AM
Last Post: dmitrymyadzelets
  Rock64 doesn't boot dstallmo 1 5,059 03-16-2024, 08:29 AM
  Boot from SPI first mjnck 1 6,206 02-29-2024, 02:12 PM
Last Post: reukiodo
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,721 11-29-2022, 11:31 AM
Last Post: Macgyver
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,767 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  boot hdd usb3 philipe 1 5,158 01-27-2021, 02:12 PM
  Sent support order status , no responses RockPro64Newbie 3 9,886 01-19-2021, 12:09 PM
Last Post: mathygreen
  Libreelec Rock64 - 4GB no boot spiker15 3 8,271 11-02-2020, 12:36 AM
Last Post: wilsonYan
  Rock64 - boot helpmerock 2 6,213 10-08-2020, 01:29 PM
Last Post: helpmerock
