Ubuntu updater fail, partical win, fail again
1) I think the first time I flashed the card withOUT using the PinePhone Etcher. That one didn't work. It just gives me flashing red LED with a click and no update is running.
2) Then, I think I used the PinePhone PINE A64 (512MB) and flashed the SD card. I flashed to the card, put the card in and plugged it in to charge. I hit the power button and it started up and I saw the UB robot on the screen saying it was updating. I ran for about 20 minutes and then went black. When I tried to power back up an hour later, I had all three colors of LED flashing and clicking but it wouldn't start.
3) I decided to start over since it sounds like that's what everyone does here. I reformatted that same card but wonder if I used a different type (exfat, etc.) So I loaded to the card and tried PINE A64 (1GB/2GB). I put the card into the phone and I only get the red flashing light.
Please help this dumbass. I am wondering if I should try to load a different OS to see if it's the Pine installer, the SD card, the SD card format type, or MEEEEEEE!!
Help.
What OS do you want on your phone?
I don't think the A64 images are the way to go...
(08-17-2020, 09:11 PM)evilbunny Wrote: What OS do you want on your phone?
I want ubuntu
(08-17-2020, 06:05 PM)Msemmett Wrote: 1) I think the first time I flashed the card withOUT using the PinePhone Etcher. That one didn't work. It just gives me flashing red LED with a click and no update is running.
Help.
Perhaps try :
 Not sure what operating system you have on your computer ?
If you have Debian/Ubuntu,  use 'disks' to zero wipe your sd card. (takes a long while to complete)
Then format to ext4.
Then use Balena Etcher to flash your preferred operating system to your sd card...
(remove then re-attach your sd card)
Next I go back to disks (be extra careful to pick the correct 'disk') and resize your OS partisan
to all or most of your sd card space.
There are many ways to do this, but this works well for me.
Good Luck
I want ubuntu
You will need this image:
https://ci.ubports.com/job/rootfs/job/ro...one.img.xz
I have run it both on emmc and sdcard.
I want ubuntu
Thanks. I'll give that a shot. I'm on MacOS Mojave and I've put aside Pine64 installers and I'm working with BalenaEtcher.
I do not have to zero wipe every time, but I think it is advisable occasionally, especially when you see the fresh install seems exceptionally slow or corrupted.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(08-17-2020, 09:31 PM)Msemmett Wrote: Thanks. I'll give that a shot. I'm on MacOS Mojave and I've put aside Pine64 installers and I'm working with BalenaEtcher.
I think the recommended way to put the image on emmc is using Jump Drive
(08-17-2020, 09:32 PM)bcnaz Wrote: I do not have to zero wipe every time, but I think it is advisable occasionally, especially when you see the fresh install seems exceptionally slow or corrupted.
Re-sizing step is skipped on UBPorts, it has its own utility in it.
But I find it necessary when preparing the Mobian sd card.
  Ubuntu Touch on Pine64 Rondarius 11 16,258 10-11-2023, 12:36 PM
Last Post: Rondarius
  Ubuntu Touch vs Standard Pinephone OS MarsColonist 8 19,340 06-26-2023, 07:50 AM
Last Post: gregb49
  Reinstall Ubuntu Touch on PinePhone with 10 drives? Peter Gamma 4 8,742 05-24-2022, 06:42 AM
Last Post: Peter Gamma
  Ubuntu Touch with OTA updates Luke 131 277,541 04-21-2021, 12:20 PM
Last Post: Nooblife
  UT move to Ubuntu 20.04 Concrete_panda 2 8,534 11-24-2020, 12:43 PM
Last Post: DrewTechs
  How to enable SSH on UBPorts Ubuntu Touch? eaglecup 12 32,758 09-15-2020, 03:42 PM
Last Post: voidmain
  Ubuntu Touch 6 brings camera to RC channel doelf 2 6,657 09-01-2020, 02:15 PM
Last Post: doelf
  Ubuntu bootloops on Braveheart lapinus 0 3,444 07-26-2020, 03:45 PM
Last Post: lapinus
Information Article: Wayland and LVGL on PinePhone with Ubuntu Touch lupyuen 3 8,581 07-25-2020, 08:50 AM
Last Post: lupyuen
  n00b questions - can I add additional repos? how is UT different from a "full" ubuntu arturo2bodegas 6 13,976 07-11-2020, 04:25 PM
Last Post: dawg161
