Kali Linux for Pinebook Pro
#81
I don't know about gnome or xfce.....
systemsettings5,,, Power Management,,energy saving, on battery tab-> button events handling checked
When power button pressed -> prompt log out dialog
Thank you guys for suggestion for disabling power button when running in level 3. Now is there another option to put unit to sleep When closing the lid? (Are there levels can be enabled?) right now battery will be out in few hours
So.... after a long time I did an update of 2020.1, took almost 2 hours
A new kernel was installed, uname -r shows no change
? Is there an equivalent of debian's u-boot-update which changes extlinux.conf??
Of course, kali has boot.txt/boot.scr
? Or are you supposed to do it manually?
? What about initrd?? Originally there is none, update has generated one
(07-11-2020, 09:30 PM)ckalapat Wrote: I've gotten Kali Linux working on my Pinebook Pro.
Simply goto https://arm.kali.org/
and download one of the latest nightly images and you should be good to go.
The 2020.2 images from
https://www.offensive-security.com/kali-...rm-images/
did not work for me either.  Either download the latest nightly build from the link above or wait for the next official release from offensive-security.
Thank you for posting the location of the ARM install.
How can I install it on my PBP, though?
Thank you.
That's not a very clear question,, write it to SD like any other image?
It would be rather rash to install to emmc without testing it for a week or 2
Especially (before your time) after the screw-up 2? months ago with kali
In short, bad image, partitions in wrong place, uboot overwritten
Worked OK as SD boot (using emmc uboot), but when installed to emmc,,
no uboot, thus no boot. I'm sure that it has been fixed, still wise to test
Personally, I always check if sleep works (well). this gives fastest computer
(09-28-2020, 11:16 PM)wdt Wrote: >How can I install it on my PBP, though?
the install on emmc is pretty clean now ...i don't even see a second of red light when it boots up
Hello everyone!
I have a problem with kali on my PBP. Burning and first boot from mSD are successful, but second boot after update/upgrade always failed. Second boot looks like this: successful start to log in screen, I'm typing credentials to gaps and push "log on", system accept my credentials, black screen for 1-2 seconds, log in screen again with empty gaps and so on ad infinitum (re-burn the image can't solve it). Image is correct (hash was compared). Please help me solve it strange situation. Thank you.
Since it is on a SD, easy to put in reader
make it passwordless
Search,, shadow or passwordless
See what happens
(05-22-2021, 09:18 PM)wdt Wrote: Since it is on a SD, easy to put in reader
See what happens
The same. I made default user 'kali' passwordless, apt-update, apt-upgrade, reboot...again log loop.
(08-18-2020, 07:39 AM)wdt Wrote: So.... after a long time I did an update of 2020.1, took almost 2 hours
Did you ever fix the kernel issue? Mine is also stuck in an older version
  Window Maker Live for Pinebook Pro vajak 8 902 01-22-2026, 08:00 PM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 12,289 08-09-2025, 06:53 AM
Last Post: Sb2024
  Can’t login to Linux fnosai 0 2,152 07-27-2025, 12:30 AM
Last Post: fnosai
  Boot Order in Pinebook Pro food 11 11,105 03-28-2025, 10:08 AM
Last Post: DrYak
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 2,185 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 4,656 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 5,854 08-21-2024, 04:17 AM
  Slackware Linux working on PBP vxzero 0 2,896 06-05-2024, 04:30 PM
Last Post: vxzero
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,232 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 9,110 03-31-2024, 10:11 AM
Last Post: u974615
