Ubuntu Touch with OTA updates
(07-22-2020, 07:18 AM)jesica Wrote: I did update my phone
still no camera
still no connection to pc
I assume the 1.2 version board does not have to be soldered to fix the issue for the pc
SD card also does not pick up
reckon its time to change a different flavor Os for the phone
I had the same thought. I tried Mobian and was shocked how well it works. Super easy to flash on an SD card. Be warned, you will be tempted to become a patron to mobian after trying it out just like me. Wink
Cheers.
still no camera
Cheers.
I put Mobian on also and it works very well yes  Smile
hello comrades i am new as i install it thanks
I had the same thought. Went to Mobian but the phone gets too hot there.
Am i the onky one that hasnt had sound working in fifteen updates???
So last downloadable build from repo is identified as #70, once you have that latest OTA update will give you #114. But where is the list of changes so i can review whether i wish to download the update before i actually do? Im not seeing associated publications anywhere.
Downloaded update today, but not sure what the version was. UBports Image part 20200731-5078 listed on the phone now. Unfortunately the Morph browser is now broken because it lists sites as "Untrusted" and will not let me "Proceed Anyway". The app store will not load either.
PinePhone UBports CE and Mobian on SD, Mint Mobile, Pinebook Pro Manjaro
Hello.
I was testing ubuntu touch and I noticed the headphone jack doesn't work, there is any way to enable it?
(08-04-2020, 12:24 AM)paju1986 Wrote: Hello.
At least no easy one. Since this feature just seams not to be implemented in UB for the pinefone.
See here https://gitlab.com/ubports/community-ports/pinephone
Yes, you can unmute it in alsamixer from the terminal. It will still play through your speakers (unless you mute them). I have had a lot of trouble with the controls in alsamixer from the Pinephone, though. It's just clunky.
  Ubuntu Touch on Pine64 Rondarius 11 17,126 10-11-2023, 12:36 PM
Last Post: Rondarius
  Ubuntu Touch vs Standard Pinephone OS MarsColonist 8 20,166 06-26-2023, 07:50 AM
Last Post: gregb49
  Reinstall Ubuntu Touch on PinePhone with 10 drives? Peter Gamma 4 9,193 05-24-2022, 06:42 AM
Last Post: Peter Gamma
  UB Touch build with debos layton-dev 0 7,475 04-23-2021, 08:12 AM
Last Post: layton-dev
  Whats the latest with UB touch? Cree 9 19,047 03-11-2021, 10:59 AM
Last Post: andybleaden@gmail.com
  UT move to Ubuntu 20.04 Concrete_panda 2 8,802 11-24-2020, 12:43 PM
Last Post: DrewTechs
  Horrible energy consume on Pinephone/UB-Touch firefox-58 9 19,374 10-15-2020, 12:28 PM
Last Post: plainenough
Star Updates stuck on stable channel. Cree 6 13,249 10-04-2020, 11:26 AM
Last Post: Giiba
  Pinephone 3G Bluetooth Working Pretty Well With Latest Mobian Updates rmcg 0 4,348 09-27-2020, 10:22 PM
Last Post: rmcg
  How to enable SSH on UBPorts Ubuntu Touch? eaglecup 12 33,629 09-15-2020, 03:42 PM
Last Post: voidmain
