Wifi / Bluetooth Board Update
OS is Fedora 5.7.8-200.fc32.aarch64
I have been content to use Ethernet Networking since acquiring the Pine64. This works well. However I would like to use the cable for another project and wish to activate the Wifi board. I have googled and searched the docs for a way to do this in Fedora. Some help from the Pine64 IRC suggested the wifi module and firmware was needed. This is a very new kernel but despite a few posts that the firmware was to be integrated  - it does not seem to be the case. Can anyone suggest how to go about this in Fedora?
Does this make sense? Still cannot activate the wlan0.
[  23.121533] r8723bs: module is from the staging directory, the quality is unknown, you have been warned.
[  23.136917] zram0: detected capacity change from 0 to 954003456
[  23.153432] RTL8723BS: module init start
[  23.157487] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
[  23.164596] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
[  23.171229] RTL8723BS: module init ret =0
[  23.186287] systemd[1]: Finished Load Kernel Modules.
[  23.201287] systemd[1]: Mounting FUSE Control File System...
Can anyone point me in the right direction to get a driver for an rpm based distro? I can do some basic hacking, but need some direction. I can get some info from Armbian if necessary. But trying to decipher the variations in the device tree is difficult for me. A lot of the pine64 users seem to be forced to use a Debian based distro which limits us somewhat. Despite a lot of hackers moving to the PBPro and Pine Phone, the Pine64 can do more if it is exposed to a wider audience.
  [split] Better WiFi/BT module? moriel5 3 9,725 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 8,165 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 40,395 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
Information Howto: Getting Bluetooth (serial console) working on Debian pfeerick 14 45,617 08-19-2019, 04:33 AM
Last Post: Roverius
  Create a WiFi hotspot on Debian 8 JulianM 6 32,888 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 15,754 09-11-2018, 02:02 PM
Last Post: gamelaster
  Installing another WiFi module on one of the buses mido2018 1 5,794 07-22-2018, 07:15 AM
  +LTS/SOPINE Footprint for the recommended Wi-Fi+BT breakout board Madhuwesly 1 4,856 04-09-2018, 04:07 PM
  Unable to activate wifi on Linux smouton 10 23,441 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 9,534 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
