No boot, garbage console text and blinking red light ...
Sad
Good evening,
My Rock64 won't boot anymore : the SD card has no issue, the text displayed at the boot is only garbage and after a time the red light is blinking twice quickly and wait 1 second, then twice b;inking again and so on ...  Sad
Could somebody help to understand what happen ?
Many thanks in advance,
Regards,
Jean
Sounds like it might be power supply related. Do you have an alternative power supply. you could try.
(07-17-2020, 05:48 PM)Rocklobster Wrote: Sounds like it might be power supply related. Do you have an alternative power supply. you could try.
The power supply has  been purchased with the board ... I wonder why would the power supply be broken as it is only used to power the Rock64 board Sad
OK, got some console output, and now the system hang with a kernel panic, or boot in emergency mode ... What goes wrong ?
Here's the output of the output :
Quote:[  23.943835] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[  23.944326] Modules linked in: snd_soc_hdmi_codec dw_hdmi_i2s_audio dw_hdmi_cec videobuf2_dma_contig v4l2_mem2mem videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 zstd videobuf2_common ro
ckchipdrm gpio_ir_recv videodev analogix_dp dw_mipi_dsi mc lima rc_core dw_hdmi drm_kms_helper snd_soc_rk3328 gpu_sched snd_soc_simple_card snd_soc_simple_card_utils snd_soc_rockchip_i2s snd_
soc_rockchip_spdif drm snd_soc_rockchip_pcm snd_soc_core snd_pcm_dmaengine snd_pcm drm_panel_orientation_quirks snd_timer snd soundcore cpufreq_dt zram ip_tables x_tables autofs4 uas realtek
dwmac_rk stmmac_platform stmmac phylink gpio_syscon
[  23.949088] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 5.4.43-rockchip64 #20.05.2
[  23.949732] Hardware name: Pine64 Rock64 (DT)
[  23.950113] pstate: 40000085 (nZcv daIf -PAN -UAO)
[  23.950539] pc : activate_task+0x54/0xd8
[  23.950884] lr : ttwu_do_activate+0x50/0x78
[  23.951249] sp : ffff80001001bcb0
[  23.951539] x29: ffff80001001bcb0 x28: 0000000000000003
[  23.952004] x27: ffff8000111d9908 x26: 0000000000000003
[  23.952468] x25: ffff8000111bff80 x24: 0000000000000000
[  23.952932] x23: ffff0000fdd09554 x22: ffff80001001bd78
[  23.953397] x21: 00000000111fa3c0 x20: 0000000000000004
[  23.953863] x19: ffff0000fdd08e40 x18: 0000000000000000
[  23.954328] x17: 0000000000000000 x16: 0000000000000000
[  23.954792] x15: 0000000000000000 x14: 0000000000000000
[  23.955256] x13: 0000000000000000 x12: 0000000000000001
[  23.955720] x11: 0000000000000000 x10: 0000000000000000
[  23.956184] x9 : 0000000000000003 x8 : 0000040000000000
[  23.956648] x7 : ffff0000fe7b1368 x6 : 0000000006420ddd
[  23.957112] x5 : 00ffffffffffffff x4 : 0000000000000015
[  23.957576] x3 : ffff80001001bd78 x2 : 0000000000000009
[  23.958040] x1 : ffff0000fdd08e40 x0 : 0000000000000000
[  23.958504] Call trace:
[  23.958722]  activate_task+0x54/0xd8
[  23.959036]  ttwu_do_activate+0x50/0x78
[  23.959374]  try_to_wake_up+0x1fc/0x448
[  23.959711]  wake_up_process+0x14/0x20
[  23.960042]  process_timeout+0x10/0x18
[  23.960371]  call_timer_fn.isra.35+0x20/0x78
[  23.960745]  run_timer_softirq+0x3a4/0x3c0
[  23.961105]  __do_softirq+0x15c/0x280
[  23.961428]  irq_exit+0xb0/0xd0
[  23.961706]  __handle_domain_irq+0x94/0x100
[  23.962072]  gic_handle_irq+0x50/0xa0
[  23.962393]  el1_irq+0xb8/0x180
[  23.962670]  arch_cpu_idle+0x1c/0x30
[  23.962986]  default_idle_call+0x30/0x38
[  23.963331]  do_idle+0x20c/0x298
[  23.963616]  cpu_startup_entry+0x24/0x28
[  23.963962]  secondary_start_kernel+0x150/0x160
[  23.964362] Code: b942e800 34000100 f941be60 b50000c0 (b949b280)
[  23.964899] ---[ end trace 56ba694517edac30 ]---
[  23.965304] Kernel panic - not syncing: Fatal exception in interrupt
[  23.965858] SMP: stopping secondary CPUs
[  23.966203] Kernel Offset: disabled
[  23.966510] CPU features: 0x0002,20002004
[  23.966861] Memory Limit: none
[  23.967133] ---[ end Kernel panic - not syncing: Fatal exception in interrupt ]---
Any help would be appreciated  Smile
  Rock64 v2.0 u-boot SPI issues ju0n 1 1,639 09-25-2026, 11:19 PM
Last Post: mysy
  Rock64 won't boot luminosity7 10 19,633 03-16-2024, 08:33 AM
Last Post: dmitrymyadzelets
  Rock64 doesn't boot dstallmo 1 5,102 03-16-2024, 08:29 AM
  Boot from SPI first mjnck 1 6,243 02-29-2024, 02:12 PM
Last Post: reukiodo
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,771 11-29-2022, 11:31 AM
Last Post: Macgyver
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,799 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Information Serial Console for the Rock64 MarkHaysHarris777 33 109,539 06-24-2021, 12:24 PM
Last Post: mikeklien
  boot hdd usb3 philipe 1 5,177 01-27-2021, 02:12 PM
  Libreelec Rock64 - 4GB no boot spiker15 3 8,299 11-02-2020, 12:36 AM
Last Post: wilsonYan
  Rock64 - boot helpmerock 2 6,238 10-08-2020, 01:29 PM
Last Post: helpmerock
