New Pinebook Pro, only boots 50% of the time
Hi all, new to the forum here
Just got my PBP delivered. I am aware of the issue with the June 2020 shipment, some batches had eMMC switch off. I checked and mine was fine. For some reason, 50% of the time my PBP won't boot. The light would turn orange, then yellow, but then nothing happens and the screen is black. I could hold the power button to kill the power, then try to restart again and again until it boots. So far the boot success rate is about 50%
Did I get a defective hardware unit, or is there a DIY hardware problem that I can try?
Thanks!
(07-13-2020, 06:22 PM)micnd90 Wrote: Hi all, new to the forum here
Thanks!
Do you hold the button down for a second and a half to two seconds or just a quarter second quick jab ?
I had a problem with the quick jab myself.
For me it is maybe 25% failure rate, but once it runs no issues at all.
I am guessing it has to do with the emmc not being recognized sometimes.
I notice that right after the orange light turns green it does a short flicker as if that was an error code. I need to look at it closer, but three quick blinks seems to happen when it doesn't boot or so, while non or two only (not sure) and it boots fine.
A push of the button that is too long or too short can cause this.
NOT saying that is the problem,
but I have had what appears to be the same problem, by pushing the power button for the wrong amount of time.
I have this same problem from day one. I have not been able to find the solution, although I have searched this forum, the Manjaro-ARM forum, the PBP wiki, etc ...
The PBP screen does not turn on when I start from the EMMC, but it does turn on whenever I do it from the microSD. In both I have the same OS, Manjaro ARM.
It appears that the screen must "warm up" to turn on when starting the system from the EMMC. When I need to work with the PBP I have to start it first from the microSD and after 2 minutes or more, restart it from the EMMC.
If someone finds an explanation and, above all, a solution, I will be very grateful if you put it here. Smile
I would re-flash the uboot on the eMMC. Everything I read in this thread indicates that all of you are actually booting from eMMC, at least as far as running uboot. It's failing somewhere between uboot code running and OS running.
@prokofiev
My second PBP, (ANSI), runs Manjaro now. After some re-partitioning and other file system work, (using BTRFS as root FS), rebooting did not work well. I found reverting to the U-Boot from the default Debian restored functionality, (for me). Now every time Manjaro updates with a new U-Boot, I give it a try, and when it fails, revert back to what I had before.
Basically I am waiting for an all inclusive U-Boot that works with the display, keyboard, supplies a boot menu and supports misc. file systems, like BTRFS & OpenZFS. Whence something like that is release, (and very reliable), I'll flash it to the SPI device.
Arwen Evenstar
Princess of Rivendale
Oh for the time and ambition I once had, that would be a fun project.
FWIW, I have steadfastly avoided updating original manjaro uboot (1908) (onSD)
With my tests with blank 1st-16M (on emmc) it booted OK
So far, I think mrfixit uboot is best, that is what I still have installed on emmc
Also a good recovery SD
  Updated Pinebook Pro? tantamount 2 2,595 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,362 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,945 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,614 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 7,067 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 11,000 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 2,140 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 9,019 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,377 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 30,386 03-09-2025, 11:17 AM
Last Post: davisthomas
