How to make the Manjaro Gnome image update
Information
FAIR WARNING: After I followed these steps and then updated Manjaro it failed to boot. Until the image itself is updated, I do not recommend installing this variant of Manjaro!
The current Manjaro Gnome image is very old. Manjaro has changed how it updates, so in order to make it update I ran the below command from this comment (https://forum.manjaro.org/t/all-mirrors-.../123901/17) in the Manjaro forums:
sudo pacman -U http://ftp-osl.osuosl.org/pub/manjaro-arm/repo/stable/core/aarch64/pacman-mirrorlist-20200225-1-any.pkg.tar.xz
and then ran pacman -Syyu after. Unfortuantely, that didn't work, as pacman was making a fuss about the xorgproto package, so after a little googling I ran the command: pacman -Rdd libdmx libxxf86dga, which removed the problematic package and allowed me to update.
Hope this saves somebody some time!
EDIT: So that brought the updates up to April. In order to be fully up to date I had to edit my pacman mirrors file (I copied and pasted this from same Manjaro forum, just further down: https://forum.manjaro.org/t/all-mirrors-.../123901/22)
  1. Edit your
    /etc/pacman.d/mirrorlist
  2. file, so only this line is present:
Server = https://manjaro.moson.eu/arm-stable/$repo/$arch
Nice job! I saw that the image was outdated but I just went the lazy route and installed Gnome/ripped out KDE from the default install - was surprisingly painless.
Apparently sometimes the lazy route is better Smile . After going through all the work to get the Manjaro GNOME image to update it ended up not booting after installing all the updates  Angry . So until the image is updated, I do not recommend installing it.
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,146 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,587 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  What's a good image to use now? [tutorial help as well] frank_philip 40 32,140 07-18-2025, 07:28 PM
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,236 03-15-2025, 01:47 AM
Last Post: frank_philip
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 17,830 03-10-2025, 01:55 PM
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,356 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,104 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 4,131 03-01-2024, 06:46 PM
Last Post: Puckla
  Pinebook Pro upgrading from the factory image yamsoup 12 17,617 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,649 02-02-2024, 02:45 AM
Last Post: frankkinney
