Lifting Trackpad
I received my pinebook pro back in January, it's an ANSI model.  The bottom right corner of my trackpad seems to be higher than the other corners.  So much so that it is higher than the palm rest.  It's something that's slowly happened over time.
Anyone else experiencing this?
(07-05-2020, 09:39 AM)p3pp3r Wrote: I received my pinebook pro back in January, it's an ANSI model.  The bottom right corner of my trackpad seems to be higher than the other corners.  So much so that it is higher than the palm rest.  It's something that's slowly happened over time.
NVME adapter installed?
Mine came that way when i received it in May.
I haven't opened the case to look at things yet
I see. I think if you follow the instructions on the wiki, opening it up might be a good idea. You may be able to figure it out. Mine didn't fit while I had the first gen nvme adapter installed, but it's better now. Sorry I don't have more info for you.
No, but I'll probably open it up again to see what's going on.
I had the same, but right from the start.
There's a foamy / spungy ground connecting thingy, I cut out part of the inside, and now the right bottom corner doesn't stick up as much.
I made sure it would still make good contact though, I recon there's a reason they put it there.
My pics and story here, look at the last post (and perhaps the first one):
https://forum.pine64.org/showthread.php?...244&page=3
(07-09-2020, 02:35 AM)robt Wrote: I had the same, but right from the start.
Cool, thanks for posting the link.
I finally opened mine up.
The double-sided tape between the trackpad and the plastic piece that holds it in place had picked up a fingerprint during assembly and was not well adhered. I warmed up the adhesive with my hot air system at about 130c, peeled the plastic piece off, removed the tape, applied new double-sided tape, and reassembled. Seems good.
  Trackpad firmware update Luke 263 593,692 07-28-2021, 12:52 PM
Last Post: Luke
  Trackpad film clockcycles 5 10,134 06-18-2021, 09:34 PM
  No keyboard & trackpad leads to no display. RMA from the US. Free parts in Seattle BitterPine 4 15,101 12-30-2020, 06:14 AM
Last Post: BetteHoward
  Does this plastic trackpad cover come off? Paulie420 7 12,919 09-17-2020, 02:29 AM
  Mouse drfting when using the trackpad jcarty 1 4,891 09-15-2020, 03:21 PM
Last Post: ab1jx
  Trackpad sensitivity barn 1 4,758 08-06-2020, 01:03 PM
  Trackpad doesn't pick up small movements dieselnutjob 3 7,468 07-15-2020, 06:18 AM
Last Post: dieselnutjob
  Stuck trackball / trackpad issue charlespine 0 3,252 06-27-2020, 03:27 PM
Last Post: charlespine
  Trackpad woes robt 22 41,827 06-26-2020, 03:03 PM
Last Post: robt
  issues with keyboard/trackpad in Manjaro, can't test other OSs joshw 11 22,503 06-25-2020, 08:11 AM
Last Post: joshw
