Arch ARM iso for Pinebook Pro
Hello. have annyone gotten the Pinebook Pro up and running with Arch? i have been trying. but everytime i come to the Pacstrap command, it freezes. and i have to fdisk and start over.
i have booted from USB with Arch ARM iso for PBP and are trying to write it to emmcblk1.
last i was trying to pacstrap /mnt linux-pbp, but i have also tryed base. but it allways stops in the process.
i have searched all over for clues, but i am as of for now stuck.... :/
dos anyone have any clue for what my next step could be? Smile
Posting the error messages you get, both off the command and off serial, would be a good start.
(07-08-2020, 02:30 PM)Syonyk Wrote: Posting the error messages you get, both off the command and off serial, would be a good start.
you are right! Smile
but as i said, the command i was using was both "pacstrap /mnt  base" and "pacstrap /mnt linux-pbp" and there is no error messages.
it starts to load and check and everything seems to work until it just freezes after a wile.
then it stands there for hours.
i also tried to DD a img file directly to the partition, but no luck.
its a almost new SD card with good reading/writings and i have used it a cople of times with other OSes, and it works very good.
but there could be a issue with the sd card...
  Boot Order in Pinebook Pro food 12 17,884 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 5,960 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,988 08-09-2025, 06:53 AM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,312 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,575 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,159 03-31-2024, 10:11 AM
Last Post: u974615
  By the way, yay arch... KC9UDX 4 5,865 03-30-2024, 10:27 PM
  Pinebook Pro upgrading from the factory image yamsoup 12 17,112 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,101 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,270 12-11-2023, 03:47 AM
Last Post: calinb
