PBP lines across screen, halts whilst running (prev. will not power on)
After a hardware failure on my primary laptop last week (display backlight failure), I was looking forward to more time using my PBP, which has had minimal use to date.
This morning, the screen started displaying various horizontal lines and obviously corrupt data, and the device became unresponsive. Was booted off SD (Manjaro, i3wm) at the time.
Power-off worked. Power-on did not. I've tried leaving to charge, and battery bypass, with no success.
I am using an Apple USB-C charger, which continues to work correctly with other Apple / Dell devices. I have not tried the PSU which came with it as it didn't come with a UK adaptor and I do not have one.
My PBP is from the second batch, I believe, has the 128GB eMMC, and arrived in mid-November.
From looking over other posts, it looks like the options to explore are:
- Removing the eMMC / toggling the switch;
- Connecting a serial cable (I do not think I have a compatible one) to check whether uBoot is loading.
Any other suggestions I have missed?
Thank you!
Now turning on and booting having:
- Physically unplugged battery;
- Removed and re-seated the eMMC.
One hinge spacer was cracked upon opening the case the first time (assumed over tightening on initial assembly?). Care is needed with the speakers during disassembly - one of the wires departed the speaker upon opening as the sticky tape didn't stick well to the case, but stuck very well indeed on the table top.
Marking as not fixed.
I left the PBP running htop. Unfortunately it reverted to displaying horizontal lines and being unresponsive within an hour. Again whilst running Manjaro i3wm off of the SD card.
Issue continue when booting the pre-installed Debian image from eMMC. PBP powers on, displays a number of short red horizontal lines, then goes unresponsive. Line occasionally flicker, but boot does not continue
Any ideas?.
The PBP has an almost distict way to boot, its 5 seconds off, 3 missipi on,
I thought the pre installed was Manjaro, ARM based not debian?
Have you flashed your emmc or is this out of the box while using an sd card?
If you flashed your emmc already it may that you installed an incorrect vesion for the PineBook Pro, known working versions can be found here:
I had a similiar probelm when flashing Arch, I used the wrong version, it booted but only to a gub menu, once flashing the correct Pinebook Pro version it booted.
Here is the link to the official supported distro versions for the PinebookPro
https://wiki.pine64.org/index.php/Pinebo...re_Release
grab a new sdcard and make a sdcard install for emergency recovery use.
i use a modified danielt debian installer.
if it doesnt boot, then the emmc bootloader is probably toast. switch off the emmc and test again.
if that works, then boot the sdcard again and switch on the emmc quickly at boot (at light).
use the unbind+bind script to enable the emmc in userspace. see wiki or pbp-run-reset-emmc in pbp-tools
backup data from emmc and write a new install to emmc.
Thank you for your replies. I have updated the title as it was now misleading as to the primary problem.
Earlier builds were not Manjaro. That is a more recent change.
SD card is fine, EMMC appears fine. Behaviour is the same irrespective of boot source.
I believe this is a hardware issue.
The machine will boot and run for a short while (from seconds to a few minutes). The display will then show various corrupt / garbage lines, and the machine will stop responding.
Possibly thermal-related; if it warms up the non-power on behaviour temporarily returns.
As the plastics are also breaking already despite minimal use, and as I’ve not got spare time for debugging the hardware, this will sadly be consigned to e-waste. Hopefully the other parts can be used for something else.
  Pinebook Pro on Debian 12 Power Issue u974615 1 4,721 03-13-2024, 10:46 AM
Last Post: u974615
  Increasing the maximum power draw dsimic 15 33,431 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 29,084 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 14,492 09-26-2022, 12:17 AM
Last Post: jonasd
  Malfunction: horizontal white streak on the screen regivanx 0 2,815 06-23-2022, 12:59 AM
Last Post: regivanx
  Troubleshooting of pinebook Pro red light and black screen wangyukunshan 0 3,997 03-23-2022, 12:10 AM
Last Post: wangyukunshan
  I broke my screen :( espenbo 3 6,175 01-03-2022, 03:46 PM
Last Post: altacus
  Blinking red light for charger, no power-on bifo 11 31,833 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 3,412 11-29-2021, 01:55 PM
Last Post: stozi
  Broken Screen vxzero 0 2,888 08-26-2021, 09:02 PM
Last Post: vxzero
