Changing regulatory domain (CRDA) on the wifi adapter
The wifi has been particularly bad with the PBP in my house, but not my other devices. I've been having issues with dropping connections and very slow connections here. Someone explained to me on IRC that the regulatory domain (CRDA) may be set incorrectly on the wifi so the signal levels and frequencies may not be lining up correctly.
So, this is what I did to get the regulatory domain set correctly to Canada with Manjaro:
1) Install the wireless-regdb package with 'sudo pacman -Syu wireless-regdb'
2) Edit the /etc/conf.d/wireless-regdom uncommenting the line with the correct two letter country code for your area
3) Reboot
You can confirm the regulatory domain of your wifi by running 'sudo iw reg get'
If it shows "Country <your_two_letter_code>: ..." then it is now set.
However, if it shows "Country 00" then it is set to a worldwide default, which may not be optimal.
I hope that this helps others to improve the wifi on the PBP.
Chris
Thanks, this is useful - I've had to do similar things to find some 5GHz APs.
wireless-regdb should be a default package on the various installs, and it's definitely not.
Quote:You can confirm the regulatory domain of your wifi by running 'sudo iw get reg'
There is a typo in your command and you don't need sudo to run it:
iw reg get
iw reg get
Thanks, I fixed it.
Information Found newer firmware for broadcom wifi (brcmfmac43456-sdio) cobratbq 4 12,450 07-04-2025, 07:46 AM
Last Post: remph
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 17,441 06-26-2025, 09:20 PM
Last Post: reukiodo
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,534 03-15-2025, 01:47 AM
Last Post: frank_philip
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 4,993 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  5GHz wifi not working snorwood 11 17,190 01-16-2023, 03:41 PM
Last Post: ehcorn
  Pinebook Pro wifi not working Queliffrel 1 3,721 11-30-2022, 06:30 AM
Last Post: myself600
  WiFi stopped on Pinebook Pro after update tkudog 3 7,543 11-24-2022, 04:32 PM
Last Post: tkudog
  Archlinux - missing firmware for wifi adapter RudderDuck 9 15,025 11-07-2022, 04:56 PM
Last Post: wgahnagl
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 7,584 08-25-2022, 02:15 PM
Last Post: Niko
  Pinebook Pro wifi not working seyo-iv 2 7,395 10-26-2021, 02:27 AM
Last Post: wangyukunshan
