kernel build script for latest mainline manjaro kernel
#41
yes, the brightness gauge changes. use brightnessctl s 100% ... it does that just the first time...
#42
(01-30-2020, 01:03 PM)xmixahlx Wrote: greetings,
included is a kernel build script, and dependencies debian-based systems (and you can modify for other systems easily... ).
this fetches the tsys/manjaro *v5.7* branch from the manjaro git, applies a config of your choice, preps, builds, and debianizes a custom kernel. build time is about 90min for the pbp, or ?min via crossbuilding. (for me is ~10min.)
you can also choose any branch in the manjaro git by changing the VAR.
enjoy!
SCRIPT
script now part of pbp-tools. see other forum thread for details.
https://github.com/xmixahlx/pbp-tools
https://forum.pine64.org/showthread.php?tid=10190
Which script is the kernel script for debian?
#43
pbp-install-linux in pbp-tools. it will make debian packages with pinebook pro and improved VPU hardware acceleration patches by default.
you can optionally crossbuild on an amd64 system, build a 5.8 rc, build without VPU patches, and supply your own config if desired.
  Building PPSSPP with Manjaro AUR LivingLinux 0 4,762 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 24,552 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 6,450 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 12,864 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 6,419 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 5,077 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing WPS Office on Manjaro brent.thierens 5 16,461 07-13-2020, 03:13 AM
Last Post: brent.thierens
  full disk encryption with luks on manjaro xfce limxr 48 111,289 07-09-2020, 07:27 AM
Last Post: JtR
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 13,530 06-23-2020, 12:41 AM
Last Post: pljanson
  mesa-git build script for latest panfrost xmixahlx 28 77,081 06-11-2020, 11:16 PM
Last Post: xmixahlx
