Linux 5.7 on Pinebook Pro
Regarding the battery icon, this seems to be a KDE bug that's occasionally popping up. The issue's up and assigned on their bug tracker: #422111
Users also wrote a couple of quick fixes. Open up a terminal, and run the following:
kquitapp5 plasmashell && kstart5 plasmashell
Source
Beware, this kernel effectively killed my Manjaro install. Basically the machine was having random freezes on this kernel, and it froze right in the middle of an update Sad and is unbootable now. Will have to reflash.
(06-16-2020, 07:45 AM)tiagoespinha Wrote: Beware, this kernel effectively killed my Manjaro install. Basically the machine was having random freezes on this kernel, and it froze right in the middle of an update Sad and is unbootable now. Will have to reflash.
You could also chroot into it and rerun the update and downgrade the kernel, if you do not want to reflash the whole thing.
  Boot Order in Pinebook Pro food 12 13,999 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 3,741 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,011 08-09-2025, 06:53 AM
Last Post: Sb2024
  Can’t login to Linux fnosai 0 2,606 07-27-2025, 12:30 AM
Last Post: fnosai
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 2,643 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 5,648 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,923 08-21-2024, 04:17 AM
  Slackware Linux working on PBP vxzero 0 3,334 06-05-2024, 04:30 PM
Last Post: vxzero
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,859 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 10,483 03-31-2024, 10:11 AM
Last Post: u974615
