Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound
Or, "As close to a daily driver OS as I can get."  Which I have been attempting to daily drive.
Post 1 is getting it installed, working, and sleeping properly, with at least "mostly works" sound functionality.  Later parts will cover various other aspects, including abusing the environment into something that can play Spotify (armhf browser in a chroot).
You'll need a microSD card and some time, with the install ending up on the eMMC.
I'm also assuming some general familiarity with Linux - I've got all the steps, but there may be some assumptions missing between them, because I didn't record the exact keystrokes.
Get the initial image, flash it to SD.
Pull the image from ayufan's repo here:
https://github.com/ayufan-rock64/linux-b...ag/0.10.12
You want focal-gnome-pinebookpro-0.10.12-1184-arm64.img.xz - it's ARM64, and Ubuntu 20.04.  Unzip this and put it on an SD card with your preferred techniques (Etcher doesn't seem to like these images, so you may have to dd it directly over - I just dd'd the unzipped image onto the SD card and it was fine).
Toss a copy of this image onto a USB drive or local server as well - you'll need it for flashing onto the eMMC.
Put the SD card in, boot, and you should find yourself at something looking generally Ubuntu 20.04-ish.  rock64/rock64 will get you in, and it will make you change the password immediately.
Flash the image to the eMMC
Find the eMMC - I think it tends to be /dev/mmcblk0 when booted from the SD card.  The 'lsblk' command will show you what your block devices are, and the one that's not got something mounted as root is your eMMC.
Grab a copy of the image again from your preferred source, and we'll put it on the eMMC.  It's worth running lsblk and unmounting anything mounted from your eMMC before you start, though it probably won't matter.  It's just rude to blow away a filesystem without unmounting it, and in theory it could mess with the flash if something got written to a half intact filesystem.
unxz focal-gnome-pinebookpro-0.10.12-1184-arm64.img.xz sudo umount /media/rock64/* sudo dd if=focal-gnome-pinebookpro-0.10.12-1184-arm64.img of=/dev/mmcblk0 bs=1M
I'm not going to say you should mount the new filesystem to do a bunch of 'sed -i -e' over in /etc and rename your home directory.  But if you want to, now is a really good time to do it.
Power down, pop out the SD card, and reboot.  You should boot into a clean image, same as you had on the SD card.
Initial System Setup and Updates
The terminal font is violently broken.  Menu -> Preferences -> Use Custom Font, and pick something sane.  Monospace is a decent one.
Connect to wireless, then we'll update the system and fix the timezone to be correct.
sudo dpkg-reconfigure tzdata sudo apt update sudo apt -y dist-upgrade -y reboot
Congratulations!  You have an updated Ubuntu 20.04 - but it doesn't have the good stuff yet.  It won't deep sleep, sound probably doesn't work, and we can do better.
Build a 5.7 Kernel and Such
Next, we'll build a 5.7 kernel from the development tree.  Bleeding edge and all.  Do this first, because the 5.6 kernel with the BSP firmware we'll flash takes about 2 minutes to boot, with a black screen in the process.
Be sure your battery is charged!  This will drain your battery down, even if plugged in.  You'll probably want to leave the screen brightness dim, but even then, the board at full tilt draws more than the barrel plug adapter can source.  Beta hardware and all.
We'll be using the pbp-tools repository, which has several useful scripts (and several scripts that will render things non-booting on this install, because the partition layout is different).
You'll need to agree to the menuconfig options in the kernel build step about 5 minutes in - just tab over to exit and call it good unless you want to explore and change things.  If you've never poked around menuconfig, it's a fun place!
sudo apt -y install build-essential libncurses-dev flex bison openssl libssl-dev dkms libelf-dev libudev-dev \ libpci-dev libiberty-dev autoconf fakeroot meson git clone https://github.com/xmixahlx/pbp-tools cd pbp-tools ./pbp-build-linux-hwaccel
sudo dpkg -i upstream/*.deb
./pbp-update-ap6256-firmware
./pbp-post-install
reboot
After you've left menuconfig, go do something else, because this takes a long time.  It's a pretty complete kernel build on a little ARM box.  Think two hours, though it might be less - I've not timed it.
Ideally, you come back to the box rebooted, in Ubuntu, with a 5.7 kernel (uname -a will show you the kernel version).  If this doesn't work... well, you have a UART, right?  You should even have working sound!
Do NOT run the update system partitions script.  It will render this system non-booting because it puts things in the wrong places and nukes the boot partition in the deal.  It's built for a different partition layout.
Flash the BSP uboot
We will, however, be flashing the BSP uboot.  This is different from the "mainline" uboot, which is fully open source.  Some of the quirks of deep sleep aren't ported over yet.  We'll be using the patched one with NVMe support, but putting it on the eMMC instead of the SPI flash chip (the SPI chip is good to avoid unless you really need to boot from NVMe, because recovering from a bad flash is somewhat harder).
Your eMMC should be mmcblk2 - use lsblk to verify, and adjust if needed.
git clone https://gitlab.manjaro.org/manjaro-arm/packages/core/uboot-pinebookpro-bsp.git cd uboot-pinebookpro-bsp sudo dd if=idbloader.img of=/dev/mmcblk2 seek=64 conv=notrunc sudo dd if=uboot.img of=/dev/mmcblk2 seek=16384 conv=notrunc sudo dd if=trust.img of=/dev/mmcblk2 seek=24576 conv=notrunc
Yes, this is putting stuff in the middle of a mounted partition (/boot/efi).  It does seem to work, but we'll do some fixup to prevent that from being overwritten.
Reboot.  You should now have deep sleep capability.  Ensure that /sys/power/mem_state has "deep" selected, and you should be able to deep sleep with fn-esc, or closing the lid.  Done right, you'll lose 2-3% battery overnight.  However, it's not always the most reliable thing on the planet, so you might still shut the system down if you really need battery preserved.  Beta dev hardware and all that.  The system will wake if you plug it in, otherwise you should be able to wake it with the power switch.
Let's Tweak the Trackpad
None of this really helps the trackpad on this system.  If it doesn't bother you, well, don't bother changing anything.  But if you're constantly clicking stuff you don't intend to click, there are a few changes that might help.  It's apparently somewhat hardware specific, but you can make it less annoying.
In Mouse & Trackpad settings, disable tap to click.  This will require you to actually click, which seems to eliminate most of the annoyances.  I'll also suggest that you can improve things by changing how you type (hands floating), and by using one finger on the touchpad - don't use your thumb to click, use your pointer finger.  Yes, it's working around the hardware, but it makes it somewhat less frustrating to use.
You might install and enable the synaptics driver - it seems slightly better, though... YMMV.
sudo apt install xserver-xorg-input-synaptics
Then modify /etc/X11/xorg.conf.d/40-pinebookpro-touchpad.conf with the suggested settings from the PBP wiki:
Section "InputClass"    Identifier "touchpad catchall"    Driver "synaptics"    MatchIsTouchpad "on"    MatchDevicePath "/dev/input/event*"    Option "MinSpeed" "0.25" EndSection
Adjust other options if needed.
Sound after Sleep
One may, rapidly, discover that sound doesn't work after sleep.  Something isn't getting reset properly, and I don't quite know what yet (this is an issue after deep sleep, not the s2idle sleep that burns 7% battery an hour).
One might try this:
pulseaudio -k && sudo alsa force-reload
If this doesn't work, something probably has sound open - try killing off the browser.  Sorry, still working out the details on sound and sleep - something isn't getting reset properly after a deep sleep on the 5.7 kernel.
A Little CPU Toggler Script
Care to mess with your CPUs?  Perhaps disable the big CPUs for light use, or disable the little CPUs for hardware virtualization experiments?  This ought to help you (run with sudo):
#!/bin/bash if [ $# -eq 0 ]; then echo "Usage: sudo pbp_cpu.sh [all, big, little, status]" exit fi if [ $1 = "all" ]; then echo "Enabling all cores." echo 1 > /sys/devices/system/cpu/cpu0/online echo 1 > /sys/devices/system/cpu/cpu1/online echo 1 > /sys/devices/system/cpu/cpu2/online echo 1 > /sys/devices/system/cpu/cpu3/online echo 1 > /sys/devices/system/cpu/cpu4/online echo 1 > /sys/devices/system/cpu/cpu5/online fi if [ $1 = "big" ]; then echo "Enabling only big cores." # Online the big cores first, then take the little ones offline.         echo 1 > /sys/devices/system/cpu/cpu4/online         echo 1 > /sys/devices/system/cpu/cpu5/online         echo 0 > /sys/devices/system/cpu/cpu0/online         echo 0 > /sys/devices/system/cpu/cpu1/online         echo 0 > /sys/devices/system/cpu/cpu2/online         echo 0 > /sys/devices/system/cpu/cpu3/online fi if [ $1 = "little" ]; then echo "Enabling only LITTLE cores."         echo 1 > /sys/devices/system/cpu/cpu0/online         echo 1 > /sys/devices/system/cpu/cpu1/online         echo 1 > /sys/devices/system/cpu/cpu2/online         echo 1 > /sys/devices/system/cpu/cpu3/online         echo 0 > /sys/devices/system/cpu/cpu4/online         echo 0 > /sys/devices/system/cpu/cpu5/online fi if [ $1 = "status" ]; then echo "Core status:"; echo -n "cpu0 (LITTLE): " cat /sys/devices/system/cpu/cpu0/online echo -n "cpu1 (LITTLE): " cat /sys/devices/system/cpu/cpu1/online echo -n "cpu2 (LITTLE): " cat /sys/devices/system/cpu/cpu2/online echo -n "cpu3 (LITTLE): " cat /sys/devices/system/cpu/cpu3/online echo -n "cpu4 (big)   : " cat /sys/devices/system/cpu/cpu4/online echo -n "cpu5 (big)   : " cat /sys/devices/system/cpu/cpu5/online fi
The Results
Do all this, and you should have something more or less daily driverable.  Install your desired software, and just go to town.  Please let me know what works and what doesn't!
Thank you for the time you took to write this down! Smile
I just wanted to the same thing, though I saw that the image I would use to flash the eMMC has only 4 GBs of space. I resized the partition (the 4th) to take up the rest of te space left on the SD, but the SD never boot. What did you do to have the necessary space there to unzip the xz image?
Boot the image as-is on the SD card, then either copy the xz over, or shut down and put it on from the remote system. I haven't found a clean way to do that all in one step.
great op post. i will update the systempartitions script for the single partition variety.
This is a great write up! If you don't mind @Syonyk I'm going to place a copy of the thread into the PBP Tutorials forum.
(06-15-2020, 07:46 PM)Thanks for taking the time on this. I had tried this previously and had to give up as I could not get it booting from the emmc. I will give this clear guide a try and report back. I really like using Ubuntu and tried Unity a while ago and that worked now have the Manjaro KDE build which is good BUT not Ubuntu.One question: I dont get what this means "I\m not going to say you should mount the new filesystem to do a bunch of 'sed -i -e' over in /etc and rename your home directory."Syonyk Wrote: Or, "As close to a daily driver OS as I can get."  Which I have been attempting to daily drive.
./pbp-post-install
reboot
Flash the BSP uboot
Sound after Sleep
One might try this:
The Results
I think you mangled your response very badly - it quotes most of the original guide. Could you edit that down?
Quote:One question: I dont get what this means "I'm not going to say you should mount the new filesystem to do a bunch of 'sed -i -e' over in /etc and rename your home directory."
If you know what you're doing in a Linux filesystem, you can skip having to create a user of your preferred username by renaming the rock64 user your desired username. 'sed -i -e' is a way of doing that, given the proper regex string afterwards. Basically, it's a clue to those who muck in filesystems and at the command line a lot that you can rename the user, but it's not completely trivial to do, and there are quite a few ways to mess things up doing it.
"Power down, pop out the SD card, and reboot.  You should boot into a clean image, same as you had on the SD card."
How long does the image take to boot from EMMC? All I have gotten after flashing my PBP multiple times is a yellow light and black screen after waiting for a long time. Very frustrating! I'm sure I flashed the right image (focal-gnome-pinebookpro-0.10.12-1184-arm64.img.xz)...
Shouldn't take very long, and I don't think you should see a yellow light. Toss a serial port on and see?
Unfortunately I don't have a UART cable Sad. Any other suggestions?
  How to rewrite uboot to emmc pineitup 5 15,669 12-27-2020, 10:35 AM
Last Post: nightranger73
  How to install Ubuntu to eMMC and to install KDE (Neon) Wizzard 66 163,813 12-22-2020, 03:05 PM
Last Post: Wizzard
  Installing WPS Office on Manjaro brent.thierens 5 16,579 07-13-2020, 03:13 AM
Last Post: brent.thierens
Exclamation Flash dhivael's SPI uboot (risky) clover 51 91,979 06-20-2020, 03:24 PM
Last Post: craftkiller
  How to boot Manjaro from NVME with uboot on eMMC as400 47 100,348 06-07-2020, 02:37 AM
Last Post: as400
  Instructions for Installing VS Code on Manjaro clover 6 22,390 06-04-2020, 09:37 PM
Last Post: pfeerick
  Installing Docker on Pinebook Pro - update 1/18/20 SuperXkoodA 4 12,579 03-24-2020, 03:19 PM
Last Post: chaoskampf
  (almost) upstream uboot/atf User 15997 27 55,428 02-08-2020, 10:18 PM
Last Post: Natrox
  Quick Guide to installing Ubuntu Unity on your Pinebook Pro andybleaden@gmail.com 19 41,174 02-03-2020, 11:17 AM
Last Post: MIchael
  Installing Wine i386 on Pinebook Pro wrzomar 0 5,115 01-31-2020, 03:52 PM
Last Post: wrzomar
