Not quite, as we're currently more in a "rolling release" scheme. Upgrading using apt should be enough to get you there.
We're making small steps which doesn't justify a proper announcement, and there are still major bugs, so I'm holding back atm, but I hope we'll have a much improved release before the end of the month Smile
(05-09-2020, 03:18 AM)dukla2000 Wrote:
(05-09-2020, 01:51 AM)Juergen Wrote: Another problem occurred the second time to me: I shut down the phone yesterday 23.00, today the battery is totally discharged. (0%)
Can anyone confirm?
Yes, the modem doesn't power off correctly so unless you remove the battery you still have 1 ARM core (A53?)  running.
Perhaps this issue is already solved - just want to mention:
The last 3 weeks I used "sudo shutdown now" I had no problems, the phone lost maybe 1-2% over night.
With braveheart?
Sent from my iPhone using Tapatalk
I have a dependancy issue with libc6 when installing build-essential on braveheart.
E: Impossible de récupérer http://repo.mobian-project.org/pool/main/l/linux-5.6-pinephone/linux-libc-dev_5.6.0+pinephone5_arm64.deb  404  Not Found [IP : 91.121.79.211 80]
It looks like the path of the package is this package is
http://repo.mobian-project.org/pool/main..._arm64.deb
not
I post it there as I can't find the right place to post in on gitlab tracker
* PinePhone BraveHeart Edition
(06-15-2020, 03:44 AM)ivanB1975 Wrote: With braveheart?
yes
(06-15-2020, 07:57 AM)Gobelin Wrote: I have a dependancy issue with libc6 when installing build-essential on braveheart.
Your apt database is probably outdated, run apt update beforehand
Thanks, I really thought I ran apt upgrade several times, but I can't reproduce it. So I guess it was an outdated database. Thank you for your reply, and sorry for th inconvenience.
Hi All!
Anyone experienced that if you remove a software from the favourites, like Contacts it disappeares from the app grid?
Can I somehow link it back?
(06-16-2020, 01:36 AM)cefre00 Wrote: Hi All!
I also see the same problem with contact.
so I tested it with a calendar, but it looks good in the office if you take it out of the favorites.
Hey, I can't seem to apt update from the repo.mobian-project.org mobian Inrelease due to no public key available...what am I doing wrong? or has something changed with the location of the resource? GPG error.
Running PureOS with Phosh on a pinephone
  Mobian image for the PinePhone Korfou 2 2,038 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,273 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,988 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 355,765 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 4,491 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,300 02-20-2025, 02:47 PM
Last Post: puffchumpy
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,642 01-15-2025, 08:08 PM
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,628 01-02-2025, 12:47 PM
Last Post: zetabeta
  atinout binaries for mobian/debian? NeutralGrey 4 5,858 10-31-2024, 04:16 AM
Last Post: astylethargic
  unofficial kali linux for pinephone help needed pinesmell 5 10,129 01-08-2024, 02:50 PM
Last Post: ERPlegend
