Can you try Xonotic? It seems to run not too bad: https://www.youtube.com/watch?v=5mpzSEKf1aM
Edit: AUR autobuild works fine. Quite playable on low settings
Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native)
06-10-2020, 02:08 PM
(06-08-2020, 01:58 PM)3xC0MM Wrote: Hi, anyone was able to install https://openage.sft.mx/ on Manjaro?Yes it compiles and works .. but not with the panfrost drivers last time I checked ..
06-10-2020, 02:28 PM
(06-10-2020, 02:08 PM)astr0baby Wrote:Can you please share the way to do it?(06-08-2020, 01:58 PM)3xC0MM Wrote: Hi, anyone was able to install https://openage.sft.mx/ on Manjaro?Yes it compiles and works .. but not with the panfrost drivers last time I checked .. Thank you!
06-10-2020, 02:39 PM
(06-10-2020, 02:28 PM)3xC0MM Wrote:(06-10-2020, 02:08 PM)astr0baby Wrote:Can you please share the way to do it?(06-08-2020, 01:58 PM)3xC0MM Wrote: Hi, anyone was able to install https://openage.sft.mx/ on Manjaro?Yes it compiles and works .. but not with the panfrost drivers last time I checked .. I will need to re-create the build steps yet again, ok please be patient - I will do it and post here
06-13-2020, 01:16 PM
@astr0baby I'm attempting to recreate the steps you took to build OpenMW on a PBP. I'm thus trying to compile mygui-gl-git, which seemed to be the most appropriate version of MyGUI, after editing the building files to allow for an aarch64 architecture. However after about 45 minutes of seemingly successful compilation of c/cpp libraries, I got an error of the form
Code: unable to evaluate 'lib/libCommon.so': No such file or directory.
==> ERROR : An error occured in package().
Giving up...
06-13-2020, 02:45 PM
(06-08-2020, 01:58 PM)3xC0MM Wrote: Hi, anyone was able to install https://openage.sft.mx/ on Manjaro?In Manjaro compiled (openage-git) AUR with no problem. I only does not own the game. can't play it. (only add aarch64 in the build-files nyan-lang-git and openage-git). See: https://forum.pine64.org/showthread.php?tid=10094
The future is here! ARM laptops!
06-13-2020, 02:53 PM
(06-13-2020, 01:16 PM)rustynkoal Wrote: @astr0baby I'm attempting to recreate the steps you took to build OpenMW on a PBP. I'm thus trying to compile mygui-gl-git, which seemed to be the most appropriate version of MyGUI, after editing the building files to allow for an aarch64 architecture. However after about 45 minutes of seemingly successful compilation of c/cpp libraries, I got an error of the form Hi, try to build the exact version of MyGUI that OpenMW recommends ie 3.2.1 https://wiki.openmw.org/index.php?title=...etup#MyGUI
06-14-2020, 02:20 AM
(06-13-2020, 02:53 PM)astr0baby Wrote: Hi, try to build the exact version of MyGUI that OpenMW recommends ie 3.2.1Thanks for your answer! I downgraded the version of mygui-gl-git to be installed, but... no dice, still the same "libCommon.so missing" error. (And on the other hand the mygui-git variant freezes mid-compilation.)
06-14-2020, 02:34 PM
Update : I managed to get OpenMW to build. But now I'm not so sure about whether I need Wine or not. The docs for OpenMW seem to indicate that I do, but (for now) I'm still failing to build it (possibly due to errors in checking my clang version ?). Anyway, If you have the time for that, could you give a bit of detail about what you did with the game files ?
Wine will not work as it needs a x86 CPU (yeah oversimplification, I know). I guess it is only used to extract the game files anyways. My suggestion would be to install OpenMW on a x86 PC and move the data files over to the PBP afterwards.
| Updated Pinebook Pro? | tantamount | 2 | 2,511 |
06-20-2026, 10:14 AM Last Post: tantamount |
| Pinebook pro bricked? | michaelmoua | 4 | 8,292 |
05-26-2026, 02:20 AM Last Post: Anthona |
Finally got Kali working on my Pinebook Pro! | qingss0 | 0 | 1,893 |
04-04-2026, 08:00 AM Last Post: qingss0 |
| dead Pinebook - help please | RicTor | 3 | 3,560 |
03-26-2026, 04:22 PM Last Post: williamcorlin |
| Pinebook problem | meghancordo | 2 | 6,994 |
03-18-2026, 08:58 AM Last Post: RicTor |
| Pinebook Pro in EU for Sale - €90 | jan_vdk | 5 | 10,919 |
02-09-2026, 12:50 AM Last Post: Anthona |
| Pinebook Pro for sale | rfm83 | 0 | 2,079 |
11-08-2025, 09:22 AM Last Post: rfm83 |
Full desktop Surfing and Absolute Privacy on the pinebook? | Www | 1 | 8,957 |
08-02-2025, 08:55 PM Last Post: KC9UDX |
Printing and scanning documents with pinebook? | Www | 0 | 5,333 |
06-28-2025, 01:25 AM Last Post: Www |
| Use SD to install new OS over pinebook debian | Rudy558 | 10 | 30,253 |
03-09-2025, 11:17 AM Last Post: davisthomas |
