Pinephone UBPorts not connecting to computer
It shouldn't matter whether the port is USB 2 or 3, apart from how much current it can deliver which will effect the charge rate. Data transfer will work the same with either, and capability will vary depending on which OS you're using. Most provide a usb network interface which you can use for ssh and similar. You may also get file transfer, either via MTP or as a USB storage device. Other options like KDE Connect and Nextcloud file sync will probably appear in due course.
Hi, I have the same issue.
I've tried using the cable supplied with the PinePhone (Community Edition) and connected to the USB-C port on my laptop (Kubuntu 19.10), but doesn't see the phone.
Hmm ...
My PP CE edition "Red cable" has USB-C --> USB-A
Did you get a USB-C --> USB-C cable , since you say using the cable supplied ?
I'm using a Qualcomm "Quick charge" charger , can even drive the PP, when Batt is empty.
Haven't tried connecting it to a PC yet.
Mass storage would be neat, but not a prio. right now IMHO.
If scp works , then i can manage wo. for a long time.
/Bingo
(06-08-2020, 02:45 PM)Aberts10 Wrote:
(06-08-2020, 12:42 PM)badisautumnum Wrote: When plugged into my laptop my computer doesn't show that there is a device connected. My Pinephone is working fine, and charging when plugged into the laptop but not able to connect to transfer files or anything.
Hoping this is right place to post this
That's not supported right now. I suppose you could try booting into jumpdrive (the recovery mode) by holding the power and volume up key, and then plug it into your computer.
Another option is to SSH into the device. Though you need to enable SSH in ubuntu touch first. (it's disabled for security)
(06-14-2020, 10:57 AM)KeithMcN Wrote: Hi, I have the same issue.
it should work with any USB-C-USB3-cable capable transferring data connected to an USB3-port on the computer. The described workaround above (booting into recovery mode) is fine for me.
PP is a minicomputer, no? why should connect the charging cable give access to the file system? Probably for that, you would need special software. Actually the idea is neat.
ssh works pretty well
  ADB support on Pinephone Sumwun 3 5,991 09-27-2023, 04:04 PM
Last Post: Sumwun
  Ubuntu Touch vs Standard Pinephone OS MarsColonist 8 20,308 06-26-2023, 07:50 AM
Last Post: gregb49
  PinePhone and PinePhone Pro 20.04 Focal Install and Update c3l@ 0 3,487 05-12-2023, 05:06 AM
Last Post: c3l@
  Reinstall Ubuntu Touch on PinePhone with 10 drives? Peter Gamma 4 9,259 05-24-2022, 06:42 AM
Last Post: Peter Gamma
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 12,131 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
  Images won't boot past pinephone logo remington_luger 9 20,666 08-22-2021, 09:56 AM
Last Post: remington_luger
  GhostCloud workaround for PinePhone mark1250 1 7,547 08-12-2021, 02:53 AM
Last Post: Uturn
  online accounts in UBports Uturn 2 7,584 03-30-2021, 09:12 AM
Last Post: Uturn
  UBPorts Not Working Pinoideae 7 17,001 03-13-2021, 01:51 PM
Last Post: KNERD
  How to enable Ethernet with UBPorts and convergence dock? piney-tim 1 5,286 11-27-2020, 07:40 PM
Last Post: piney-tim
